There are no grooves, they just push back in. Make sure you keep an eye on the fluid reservoir as Alex said.
Thanks peeps, will get on to this on the weekend.
Once I take the fluid out do I leave the resivour cap off until I have pushed the piston back in or just take out what I need to, replace the cap, then go work on the calipers, push them in, start the car and then refil if required? Or am I missing a few steps? Is it ok to give one of you guys a call RE this just to run through it?
always replace cap whenever your not filling or taking out- prevents debris and brake fluid is hydroscopic, meaning it attracts water.
may have just made that word up. :P
Don't take all of it out (then you'll have to bleed them all), just a little bit,like inbetween the max and min, and then push the piston back a bit and check it again- you'll get the idea.
Ooooh; sooo close!
Hygroscopic; Readily absorbing moisture, as from atmosphere.
The rest is fine. Don't forget to work from the furthest point to the closest point; think rear left corner to front right corner.
Now; back to your normal programming. Grammar Nazi out.
Edited by Daleo
Ooooh; sooo close!
Lol, had heard it said, but not written before. Thank you. :3some:
  • 1 month later...
WHEY! +1 Another M35 owner to the list here as of today.
4th consecutive Nissan owned. Such a nice car, absolutely love it. Smooth, comfort, with a big slap of boost on tap.
Must admit, she's thirsty though!
Like all 1.7tonne turbo v6's
Mine's ~1.8t plus whoever & whatever I have inside. I could get into the 9's (just) on a trip, otherwise 10.5 - 11.0L/100km on stock turbo. Don't know current consumption since changing turbo, but probably a bit worse.
  • 4 weeks later...
Hey GUYS, I'm interested in the M35, they're all auto !! i would like to convert one to manual !
For example: a 2002 model Nissan Stagea (NM35) 250 GT RS 4 V, has a VQ25DET engine, however, the 2002-05' Nissan Skyline (V35) comes in a VQ35DE but in a manual.
Is it possible to connect V35 3.5litre gearbox to the M35's engine ?
Seb
(ps- sorry if this has been said somewhere else as I haven't seen it yet)
Hey guys, I got an airbag light flashing on the dash - no idea how or what has triggered it. Just keeps flashing continuously. Anyone had this before?
Yeah, so many people it's not funny.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
