....also RS has a triple gauge set-up below the single din stereo; boost, voltage and torque split. DO NOT look at torque split whilst going around a bend with your foot down to see if it moves, you may well crash.................lol
Could someone please tell me which is the feed and return line for the transmission fluid on the radiator..I have no way of checking as I've drained my tranny fluid for the shift kit and my turbos out...in a bit of a pickle guys :)
Thanks
I've posted it somewhere, can't remember for the life of me where. I *think* the top is the pressure flow out, and the bottom is the return. But I might be wrong! Worst you can do is hook it up, and swap it if you get it wrong.
Here is something useful, seeing this post was lacking usefulness. I'm guessing your installing a cooler? Start the car when you have itall back together, and let the fluid heat up. Once it's hot, and you've checked for big leaks, re tighten all the clamps. They will go tighter once the lines are nice and warm. Otherwise you get leaks when hot.
Thanks
top is hot and bottom is cold on the solid lines.
  • 4 weeks later...
Does anyone know which version of Nissan Fast has the parts for the M35?
have downloaded 3 versions (2001, 2010 and 2010 DVD version). None of them have M35.
I have seen some guys here provide screenshots for people who have provided their M35 VIN numbers.
What version are you guys using?
Where can i get polyurathaine bushes for my whiteline swaybars. Ive seen the fronts only on ebay.
Whiteline sell service kits for all their swaybars; tell me what you want, I'll get them for you. ;)
Just blowing out hot air.
Not in my car, in a mates who I fitted an A/M deck to. Was working ok and straight after but now seems to have stopped. Just blows hot air. Don't think it's anything I did as the controls are only one plug and they still work.
Mine is the same. Figured it needs regassing.
If it only blows hot air check the plug on the cabin temp sensor thats near the drivers left knee (sits behind the panel you take off). I'm assuming they might've disconnected some of that whilst fitting the deck
I fitted the deck, you trying to say that I am incompetent Dunc, that hurts my feelings... :P
Will get him to check that as my mate actually fitted the under cover...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
