....also RS has a triple gauge set-up below the single din stereo; boost, voltage and torque split. DO NOT look at torque split whilst going around a bend with your foot down to see if it moves, you may well crash.................lol
Could someone please tell me which is the feed and return line for the transmission fluid on the radiator..I have no way of checking as I've drained my tranny fluid for the shift kit and my turbos out...in a bit of a pickle guys :)
Thanks
I've posted it somewhere, can't remember for the life of me where. I *think* the top is the pressure flow out, and the bottom is the return. But I might be wrong! Worst you can do is hook it up, and swap it if you get it wrong.
Here is something useful, seeing this post was lacking usefulness. I'm guessing your installing a cooler? Start the car when you have itall back together, and let the fluid heat up. Once it's hot, and you've checked for big leaks, re tighten all the clamps. They will go tighter once the lines are nice and warm. Otherwise you get leaks when hot.
Thanks
top is hot and bottom is cold on the solid lines.
  • 4 weeks later...
Does anyone know which version of Nissan Fast has the parts for the M35?
have downloaded 3 versions (2001, 2010 and 2010 DVD version). None of them have M35.
I have seen some guys here provide screenshots for people who have provided their M35 VIN numbers.
What version are you guys using?
Where can i get polyurathaine bushes for my whiteline swaybars. Ive seen the fronts only on ebay.
Whiteline sell service kits for all their swaybars; tell me what you want, I'll get them for you. ;)
Just blowing out hot air.
Not in my car, in a mates who I fitted an A/M deck to. Was working ok and straight after but now seems to have stopped. Just blows hot air. Don't think it's anything I did as the controls are only one plug and they still work.
Mine is the same. Figured it needs regassing.
If it only blows hot air check the plug on the cabin temp sensor thats near the drivers left knee (sits behind the panel you take off). I'm assuming they might've disconnected some of that whilst fitting the deck
I fitted the deck, you trying to say that I am incompetent Dunc, that hurts my feelings... :P
Will get him to check that as my mate actually fitted the under cover...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
