with my OS tripple I never stall it, can do hill starts no problem. even with a small 'take up zone' all you need is a small amount of clutch control to drive it easily. so practice up.
i call bulshit!! recall someone stalling when someone took me for a spin... lol
I think you guys need some serious driving practice. I haven't driven a clutch yet I couldn't get the hang of within half an hour.
I'll second that, I never have problems with any clutch after a few starts . You guys think the Nismo twin is bad in traffic........I would have to say its one of the best twins to drive .
The next best is a stocker full face plate but it won't hold much..
I had an unsprung HKS twin plate. The tuner stalled it, the shop owner stalled it and then I did. But I soon got used to it, first day I got stuck in a traffic jam on the freeway...every set of lights was a mini launch. You just have to be more switched on and purposeful in your driving. Sprung center doesn't require much concentration at all
I was helping out at the last SAU dyno day driving cars on and off the dyno. Even Daves tripple plate didn't get me although I was warned about it. What's this thread about again? I forget. Yeah, umm, you'll get used to it.
I my own cars I've had standard, nismo single, heaving duty exedy single, OS twin (solid centre) OS tripple (solid centre) and quickly adapted to all of them. I've also driven tilton twin, carbon single, and various twins, singles and tripples.
i agree with you, but the single plate i had in my rb20 was with no exageration 100 times harder to drive than my os twins and the os twins were harder to drive than the os triple.
actually the os triple is real easy to drive for a big hp clutch
definately hard core singles are much less friendly that hard core twins and tripples. basically to get a given single to hold the same power as a given twin you need a much higher clamp force in the single (as you are working with half the surface area) so hard core singles are generally the worst.
Fits my experience.
I still fight with the JB Full Monty in my GTR.
Jumping from car to car to 4wd etc and then get into the GTR occasionally - bastard red faces me every time. You try to be quiet/gentle taking off in traffic and it is easy to stall. If rolling ever so slightly its fine and you do get used to it again fairly quickly. I have noticed it is not a clutch to ride as it glazes quickly and needs a bit of harder action to clean it up. Can launch like a rocket though.
Just need bigger sunglasses and darker tint on the windows. lol
well some people have it and reckon it's easy to drive. they reckon mine isn't installed correctly...
it's actually really light, but has a hair trigger - on or off.
it's only done about 1,000kms, so might get better with some time.
it can be slipped, but I don't get 'used' to it as it get driven about once or twice a month :(
you might like it...
If I drive my GTR often, the ORC twin plate is great. It's only when I'm not thinking that it bites me.
The most annoying part about it that's dificuilt is that the friction point is more than half way out on the clutch pedal.... so you have to keep releasing your foot to almost the end of the pedal travel. That makes it hard to find and hit's as a surprise sometimes.
If it was closer to the firewall, it would be so so so much easier.
However, I've fallen in love with the clutch and wouldn't go for anything else now.
yeah i found this was the biggest issue, you slowly bring it up... and up... and up... then POW!
update guys: im getting much better driving these twins now, only hill starts are a bitch, i just take my time hahaha. I wouldnt go for anything else in saying all this, as when it catches, it catched hard, and i love it, im so used to stalling the car, its become 2nd nature on the street, but yeh im down to about maybe once every 3 days?....getting there slowly:)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
