Just did some back to back testing using a pair of Blitz steel mesh pods and a stock R32 GTR airbox with paper element filter.
Car pulled 268 rwkw on 10 psi with pods. Fitted airbox and dropped 40 rwkw. Took bottom off airbox and taped panel filter in place, back up to 268 rwkw.
I was a firm believer in using the stock box and panel filter but clearly above certain power levels it has limitations. Just my 2c into the stock airbox vs pods debate.
Cheers
https://www.sau.com.au/forums/topic/187003-airbox-vs-pod-back-to-back-testing/
  • Replies 63
Got a chance to try a 33 airbox? :)
Maybe there is a big difference, also depends on the type of panel filter.
Plenty of cars here with near enough results airbox vs pods.
Makes it interesting :)
I like the stock air boxes too, I dropped ~10rwkW when I went back to the stock air box and K&N panel. Except the dyno results were about a week apart so something could have changed. Didn't feel any difference, K&N pod was just heaps noisier.
The inlet to the side of the box is actually blocked off(r33 gtr box). It is a resonator. You can pull the end of the resonator off so air goes direcly into the box from the inner guard. u get a slight induction noise too lol
ps anyone wanna give me a guide on how to install a ebc on a rb26?? some say u just unhook the factory solenoid and plug it into the ebc solenoid?? i thoiught u would need to do it on the wastegate side??
  rev210 said:
bonnet down on those tests?
If not , we aren't anywhere.
no, bonnet open. i don't agree that we aren't anywhere. i think we can categorically state that the stock airbox will inhibit power due to the size of the orifice in the bottom half - bonnet up or down - but clearly the panel filter (tested up to those power levels) has the capacity to flow sufficient air if fed correctly.
i know there's a lot more to the issues of airflow and under bonnet dynamics but this shows conclusively that the bottom half of the box can't flow sufficient air.
i'm not suggesting that this is the be all and end all of tests, but it does tell us some things for sure. got to start somewhere, suffice to say i was happy with the outcome as i now know more than i did.
Edited by Scooby
yes..
but
bonnet up with open to air pod filters will obviously breath better than a sealed box with a small intake.
bonnet down would have shown different results on the pod filters I'd say..
especially say after 2 WOT runs.
I strongly disagree that at those power figures that the bonnet open or closed would heavily influence pods at all unless heat was a serious issue, and ACT is still cold. Ther is plenty of available air around the headlight. Clearly the 32 box is a restriction but with modification, say a 90mm water pipe flange and a pipe through the inner guard 33 GTR style it would be more than adequate for most track applications.
Some pics for Duncan.
33GTR front and 32 rear
33 GTR
32GTR
33GTR
My custom box prototype on the track car using the std air filter and an internal bellmouth from the HKS pod on the inside top (the only good part of a HKS filter). It's a tight fit around the filter so the tape is only to hold it in position and the afm is mounted directly to the top. The from bar is intended to have slots to help feed it.
It's all good mate, I majored in aerodynamics at the one uni in the country with a Mach 3 wind tunnel or what we call a shock tunnel, amongst other useful stuff.
While a simple approach would be to say that at least an extra 40rwkw would be available given Marks experience above, it depends on what the turbos are able to push, mass flow wise in Marcus' case. I forget your setup mate, but a fair guess would be a bit is available at that flow rate. Negative boost theories are all well and good but turbos have one simple role and that is to drag air in and compress it for delivery to the combustion chambers so it overcomes many restrictions, up to a point.
Mark, having a think about this and were any of the turbo inlet hoses constricting? If the restriction to the inlet was enough there may be some cross sectional reduction in the inlets between afm and turbo which is a sure way for the restriction to increase so limiting flow. If hard pipes were used, for example, then they would resist the negative pressure and allow the flow to continue. So just a thought.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
