Advanced Driver Training Course - Sandown - Sat 19 Jan 2008
  • Replies 81
Posted Images
  • 3 weeks later...
  • 4 weeks later...
Guys
This course is 50% full, which means we still have a few spots left :banana:
So if you'd like to come along (or know someone who might like to come along) please email me to book your spot.
[email protected]
Kind regards
Kev
No timing devices will be provided. its not a sprint day its a driver training day.
Guys
Just so there is no confusion...
This is not a trackday (there will be no high speed laps of the circuit), it's an Advanced Car Control day (ie we will be doing Advanced Car Control exercises)
Have a Happy Christmas :D
Hey Kev,
Do you think I would get much out of a day like this?
I'm sure you can teach me a few tricks...
I'm always open to self improvment.
Would be interested to hear what you think...
Ta, Chris.
Hey Kev,
Ta, Chris.
Yep, I recon you'll get plenty out of it.
I've got some very good, very experienced Guys instructing on the day...
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
