Hi all, im new on here so first of all hello to everyone.
I'm hoping you can help me out.I've purchased a Bee-r rev limiter and im having trouble wiring it in. I've printed off a few different diagrams and pinouts etc and connected it exactly as per drawing but nothing happens. It does light up every now and then but it wont limit the revs.I run a PFC and have put on the exta earthing wire but still no joy.The unit I have bought is second hand and i have noticed some differences not shown on the drawings.The two loops are different colours as to what they should be, mine are green and grey and not green and blue. (is this an older model??).Plus what are the other extra wires for ?? (ie theres a spare blue and grey wire "not looped")
I have pics if there any help
Cheers
Mike
https://www.sau.com.au/forums/topic/188506-bee-r-limiter-on-r34-gtt/
GREAT FOR POPPING RB'S......... seen 3 rb's now with cracked pistons from owners who abuse these things..... look at me my car sounds cool..... oops look at me its now fcked.
yeah i've heard that a bunch of times now... :happy:
is there ever really any gain from one on an unopened block, or does the danger outweigh the benefit?
wow uras is that true
even if u set it to like 3k and get some flames going?
crazy, rofl then y bother
These are the instructions i used to install the limiter on my 34 http://www.driftworks.com/resources/bee-r-...fitting,16.html
I had the same prob with the two wires listed wrongly, btw ive had the bee r limiter on my 34 for about 12 months now with hitting it atleast once a week and hasnt missed a beat, id say there would be other problems then blaming it on the rev limiter as a excuse for there stupidity...
very interesting to hear. ive changed my mind on getting one of these now.
Yeah I'm all for them now I know what their used for. My car came with one already half installed (previous owner over 50yrs did not mention it as did not know what it was), so I did some research and found out it was an engine life saver if anything for those who don't know when to change gears.....
It is a handy engine saving device (but will aid in Diff destruction if using Launch controll which was not wired into the Handbrake) I have set mine to cut out at around 6500RPM, it cuts out your ignition not the Fuel like the standard ECU, therefore saving your engine from leaning out as the standard ECU cuts fuel, obviously the fuel pump and injectors etc is the next limitation to cause premature engine melt down. But when it cuts ignition then the engine backs off and back onagain there is a big dump of fuel that gets ignited through your exhaust, not the best thing for a Cat converter if your doing it for a flameshow as I've herd some people do.
I have herd of some people wiring in the Launch control to their clutch pedal via an electronic switch aswell which would be sweet, so when they want to launch at a cirtain rev it's just dialed into Number 1 dial, pop the clutch in hold down acceletator then let the clutch go instead of handbreak and full RPM is back on tap.
I've told my wife if she ever see's a little red light flashing at her from it to change gears quickly if she's ever in a hurry, it does help though when your giving it some all you do is watch the tacho, then the light flashes momentarily you know it's time to change gears saving your engine from a redline held gear change....
Cheers for all the advise and info, I,m going now to my mates to have another go at installing it, and to test it has he's already one fitted so can plug mine into his (make sure its not faulty being second hand). Hopefully all will go well
mike
if the gray wire is cut, then the 1st owner ran it on a 4 cylinder. The gray wire needs to be intact to operate on a 6 cylinder. and the brown wire is for rotary. so the gray wire MUSt be together for the bee-r to work on any 6 cyl
  • 5 years later...
Hey guys sorry for bringing up an old topic but rather than opening a new one I thought I'd just ask here, when you connect the bee-r to the loom, do you cut the wires off the loom so that they do not go to the computer or just splice them in, thanks for any help in advance, thanks.
Hey guys I installed my bee-r and it seems asif something not right, it doesn't pop or go ba ba ba ba it's more like baaaa and then the revs drop then baaa then the revs just drop and the car kind of goes quiet, what could this be? It's run right like once or twice but that's it, I think before I installed it my little shit of a cousin turned the knobs when I wasn't looking and I noticed that the knob can just keep on turning and not stop, do you think maybe that's something stuffed? On the installation diagram that I got from here says to connect the yellow wire to pinout 44 or 45 which one should it be on, I have it on pinout 44 is that, also it's popped engine fuse number 2 why could this be, by the way it's on my R34 gtt, any help would be greatly appreciated, thanks.
  • 1 year later...
  • 3 weeks later...
Hahah took me 2 days to figure this issue out on my r32 gtr..
Basically, Bee-R needs to know the reading from your tacho sensor. Which i believe is pin 7. Splice the green wire to the 1* CAS pin (42 i think) and the yellow wire to the Tacho sensor (pin 7) .. HAPPY DAYS .. let me know how you go or if this made any sense to you
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
