well dropped off my car to hypertune for some changes and here r some b4 and after shots!!!
they f*kd it up alright haha im rapped :D its finally done!!
from this
to this!
another pic
gonna see how much power i can make b4 fitting some gas :( should see some track time once my cage gets made and a few other little bits n pieces i have yet to finish on it.
https://www.sau.com.au/forums/topic/189514-hypertune-fkd-up-my-car/
very nice 26. how much did it set you back? i think everyone wants to see a breakdown of your expenditure! i know i do!
its my goal in life to own a godzilla of similar stature. but id paint it yellow, and replace the wing with an a/m. the stock wing is awful!
hahah lets not go into cost, but a minor breakdown, the engine bay still needs a hand polish :D hasnt been done yet
2.7 jun stroker, t88 38gk turbo kit, 19" racing harts, 6" trust cooler thanks to CRD
5 spd ppg synchro box and heaps and heaps of little parts thanks to ian at hi octane
full custom suede interior with bride inserts etc thanks to custom trim works/doran
hypertune did the following for me,
tidy up all engine wiring
plenum, throttle body, intake, water breather setup, catch tank etc etc heaps of fabricating parts!!
i believe its one of the best in aus, may be biased, but thats wat i honestly think!
oh and my carbon bonnet and boot with n1 lip are coming, and n1 3 piece skirts with carbon pods. all on there way
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
