  • Replies 76
Two different quotes and two different interpretations.
Now if you believe that using cut slicks would enable the GTR into the 7:30 then your dreaming.
We shall see when the first production GTR actually tries to tackle the ring, whether or not its as fast as the CGT.
It says around 7:30 in the dry with cut slicks and that 7:38 was on a partially wet track.
Who knows until it happens.
what makes you guys think that nissan is the only company that do their best within what they think is 'fair' to get a good time? what tyres did the porsche use... etc etc.. why is nissan the only time people seem keen to challenge. I would trust them over the german marques to set an 'honest' time.
I have spent plenty of time in Germany and Poland, the chances of getting a dry track depend on weather conditions which are good for a substantial part of the year.
A little bit harder around the ring though with its changes in elevation, or so ive heard. Its a bit like Bathurst.
I just watched the video. you can see what tyres they are using. regular street spec bridgestones. why would they use anything else? you can even hear them protesting in the video. I've never heard slicks make noises like that. not even semi-slicks sounds like that.
I've already seen this discussion on another forum...
You can see them put the tyres on in their video. They are Bridgetstone RE070 tyres. The same tyres they supply with the GTR from the dealer. Why would they use anything else?
I've got no idea on what monarocountry is trying to get at here.
He's blabbing about the 'cut-slicks' on the ls1 forums aswell. Me thinks that someone is in denial that the GT-R is indeed an absolute legit weapon.
Pretty pathetic attempt to try take the light away on what truly is a remarkable piece of machinery.
Cheers,
Steve.
The Nissan, the... we all know that no one who speaks German could be an evil man!
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
