  • Replies 76
Two different quotes and two different interpretations.
Now if you believe that using cut slicks would enable the GTR into the 7:30 then your dreaming.
We shall see when the first production GTR actually tries to tackle the ring, whether or not its as fast as the CGT.
It says around 7:30 in the dry with cut slicks and that 7:38 was on a partially wet track.
Who knows until it happens.
what makes you guys think that nissan is the only company that do their best within what they think is 'fair' to get a good time? what tyres did the porsche use... etc etc.. why is nissan the only time people seem keen to challenge. I would trust them over the german marques to set an 'honest' time.
I have spent plenty of time in Germany and Poland, the chances of getting a dry track depend on weather conditions which are good for a substantial part of the year.
A little bit harder around the ring though with its changes in elevation, or so ive heard. Its a bit like Bathurst.
I just watched the video. you can see what tyres they are using. regular street spec bridgestones. why would they use anything else? you can even hear them protesting in the video. I've never heard slicks make noises like that. not even semi-slicks sounds like that.
I've already seen this discussion on another forum...
You can see them put the tyres on in their video. They are Bridgetstone RE070 tyres. The same tyres they supply with the GTR from the dealer. Why would they use anything else?
I've got no idea on what monarocountry is trying to get at here.
He's blabbing about the 'cut-slicks' on the ls1 forums aswell. Me thinks that someone is in denial that the GT-R is indeed an absolute legit weapon.
Pretty pathetic attempt to try take the light away on what truly is a remarkable piece of machinery.
Cheers,
Steve.
The Nissan, the... we all know that no one who speaks German could be an evil man!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
