R34
1 - First pull out the ashtray and undo the screw behind it.
2 - Pull up the gear stick surround and undo the 2 silver screws at the bottom left/right of the storage bin.
3 - Using a thin flat blade screwdriver on the left side, prise out the 2 vents at the top of the console and disconnect the unit.
4 - Undo the 2 silver screw at the top of the heater controls.
5 - Pull out the heater controls, radio & stage bin (all in a cage together).
6 - Remove the radio from the cage (2 screws each side) and fit your radio.
7 - Refit going from step 5 back
https://www.sau.com.au/forums/topic/190825-head-unit-removal/
Nice guide :/ here's the 32:
R32
1. Pull out ashtray like below, undo two screws behind it
2. Flathead screwdriver under the rear of the center console, push up, it will pop out
3. Flathead screwdriver under the top half of center console, pops out, remove center console, or turn it around
4. Undo 4 screws, two either side of headunit, pull headunit out
5. Undo cage holding onto headunit, refit to new headunit, finish wiring off and put back in hole
6. Refit going backwards from 4 :D
was I your guinea pig chris???
keeep it on topic guys.
my intent was to get this stuck to the top so everyone would stop asking how to get them out and stop filling my PM box u :spank:
jon,
can't remember done too many of the things.
  • 3 months later...
R33
remove ashtray
remove 3 screws
unclip panel around shifter
remove two more screws below radio area.
unclip main surround
unclip wiring from: clock,hazards,rear demist , A/C temp sensor, electric mirrors
remove main surround.
remove 4 screws from radio assy.
unclip HVAC and radio wiring.
contact me for pocket,harness and antenna adapter
remove 4-8 screws from radio and put yours in place.
reassemble.
Edited by Chris Rogers
  • 2 months later...
R34
OK I used Chris's instructions and a couple of extra things that he told me about so here is a slightly more detailed description with pics.
The ashtray just pulls out with no significant force needed. I just pulled on the open lid.
This takes a bit more force, I pulled from the back near the handbrake and levered it up with my fingers. I also pulled off the shift knob at this time but you could probably do it with it on but I thought it would be easier with it off. There are 2 screws at the front of the knob, put the shifter right back in low to get easier access. It takes a little bit of maneuvering to get the surround over the front of the shifter indicator and be careful not to scratch the vinyl with the hard edges of the surround. Unplug the lighter, lighter surround light and steering wheel shift switch. All plugs have a release tab, push it in or you will get real cranky trying to get em off.
3 - Using a thin flat blade screwdriver on the left side, prize out the 2 vents at the top of the console and disconnect the unit.
This is the panel that houses the 2 vents and the hazard switch. I used some masking tape around the screwdriver to avoid scratching the vinyl when levering. Unplug the plug at rear.
4 - Undo the 2 silver screws at the top of the heater controls.
I put some toweling over the lower console area to avoid scratching the vinyl.
I undid a couple of extra screws to "open" up the cage a bit to allow the radio to be removed and the new one installed more easily and without scratching anything.
Mine had the aerial adapter already fitted as there was already an aftermarket deck installed but the previous fitter had butchered the wiring loom so it was a bit more work to re-wire all the wires in a decent manner but if you are removing the stock deck then get the correct plug adapters and aerial adapter available from Chris or some auto outlets. I also bundle any wire slack in some padded tape to avoid any rubbing or rattling later on.
I connected everything up and tried all deck functions before re-fitting the cage permanently just in case but luckily for me all went to plan.
Hope this helps, Mark.
  • 5 months later...
  • 1 month later...
  • 1 month later...
this really helped me out!!
I just thought i would add that to get the gear surround out it actually a little lever point for you to put a screwdriver by the handbreak at the back. i was having trouble working out how to get it off untill i spotted that.
  • 3 months later...
  • 3 months later...
might sound stupid but, how do u disconnect the plug behind (the wire connection) the car lighter, there are two of them, one is bigger than the other... seems like it would not come off however from the picture above, obviously 2KR34 can took them it off..
i just dont want to break it because i use it for a lot of thing to charge my ipod, gps, and when i left my lighter.... basically half of my life depends on it.. :)
pls help someone
its for a 34 btw
cheers
bly
  • 6 months later...
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
