oh also... theres a cutout GT-R with the turbos stickin off it... can you try to get the serial numbers off it? and someone there what cosworth and all those companies once rumoured to collaborated on the GT-R ended up contributing.
  • Replies 185
nothing... just think it rates highly in comedic value... tho whole time he was babbling on about the GT-R being the ooooltimate expression of Nissan's pipe dreams I felt like punching him on the cock.
plus he oversaw the split of the GT-R from the Skyline lineage.
Well ill thank him for seperating the skylines into "GTR" and "the rest", THEN you can punch him
As the title reads, ill be going to the show on Sunday to shoot the GTR. Picked up my DSLR D40X from my friends at Nikon tonight.
im so tempted to have a major dig at Rezz right now.
If there is anything you think i should shoot, let me know. We all know about the shape of the car and the engine specs and diameter of the wheels...
what shots would you like to see? Let me know!
Are there any cars that werent covered in other websites, for example...nah.i wont, like the new Lambo Reventon that you would like to see?
Ill be taking a ton of photos so let me know what you would like to see.
Well there is a rumor that in order to fit the two turbos under the V configuration, nissan had to cast the exhaust manifold & the turbine exhaust housing as one solid piece. Could you see if you can get a photo somehow?
Cheers
ive already told you munkster..im not going to punch Ghosn on the knobend...he might take it the wrong way.
the Reventon is one of the cars ill be taking shots of. I should be able to get shots of the inside of the GTR.
Munkey magic, were you serious about your requests or are you taking the piss out of me as well as Ghosn? :)
well i would love to see the rear mounted transaxle and transfer case, as well as anything from the motor. but I somehow doubt you will get under there. feel free to prove me wrong lol
LOL, if anyone has heard and seen my antics in getting into the paddock at Suzuka last year without a pass will know i am damn capable of Houdini like maneuvers..
Ill see what i can do.
cheers.
There is the cutaway GT-R there which shows it clearly but no closeup pics online yet.
I would be very interested in seeing more of the transaxle and the massive errr "nose shaft" from it!
Edited by Laurence
yeah interesting solution to the nose heaviness problem, I think a couple of cars have gone this way over the years like corvette, maseratti coupe etc. WIll make it a shit load easier to pull the motor in an out (and much harder for the gearbox/diff/xfer case)
Clear pics of the dash
Around the radio controls
Screen controls
Traction controls (that section above the gearknob)
Indicator stalks
Close up of speedo/tacho
Inside glovebox
These are all on the Nissan Press website already:
http://press.nissan-global.com/NISSANGTR/E...otographs2.html
Munkey magic, were you serious about your requests or are you taking the piss out of me as well as Ghosn? :(
I was actually quite serious about everything except Ghosn. I wanna see them suzuki girls they're rumoured to be sensational... and the new Honda CR-Z hybrid. Plus the cutout is really cool. one of the other guys took a walk around vid of it, but I'd love to know what turbo's they're using.
yeah sewid's link is awesome. the front and rear subframe detailed shots show that there has been surprisingly little change to the subframe design, they would be 90% the same as 32 gtr, lots of minor improvements obviously but the basic shapes and mountings are the same.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
