It's on again - the annual club-member awards. These categories are separate to the track awards and will be presented at the final club meeting of 2007 - Tuesday 18th December.
This is a chance to reward those members who make that extra effort and who really make the club what it is - a true honour to acheive.
All members are eligible to vote and all members are eligable for all of following categories.
We ask that you keep your specific nominations private by sending an email to the address below. Feel free to discuss and ask questions in this thread though.
Email your nominations to: [email protected]
Nominations Close: Sunday 8 December (at the conclusion of the Show N Shine / Xmas BBQ).
Note:- I 'may' have to bring the date back a bit as the time gets closer. Will depend on timing requried to get trophies/etc organised. Will keep you posted.
1. Thread of the year
What was the most memorable thread this year for you?
2. Rookie of the year
Who's come along and had a big impact in there inaugural year at SAUVIC?
3. She'll buff right out award
The annual Mines Datsun trophy – those fences can jump out at anyone!
4. Motorsport junkie
Come rain, com hail, come show or shine - who made an effort to get to events?
5. Most improved car
It's the 90210 trophy for the car that just keeps getting better and better.
6. It's not a Skyline but we still love you award
Not everyone packs an ‘R – the trophy for a member without stove-tops.
7. Photo of the year
Nominate one you've seen - or one you've taken. What celluloid masterpiece takes the prize?
If you can email the pic through, it would be appreciated.
8. The Troy S Brisby Memorial Trophy
Who was there, taking one, or two for the team - often in the shadow of greatness - on time, every time.
9. Club member of the year
The peak. The zenith. The capstone. The best of the best.
10. President's award
Awarded by the president’s discretion. Nominating for this wont do you any good.
Only one submission per member for each award.
Good luck to everyone!
Cheers,
Bec
https://www.sau.com.au/forums/topic/191433-2007-sau-vic-club-awards/
  • Replies 65
Posted Images
Photoshop is something that has been somewhat lacking this year, so we thought we would try out a new category in its place "Rookie of the Year".
Lol....care to list some of the rookies this year :D I was trying to think of some and everyone I thought of has been here a little while :blush:
Buff right out award i can think of 3 off the top of my head.
Troy@Sandown
Leewah@DECA
And Justin@PI
Justin wins by a mile!!!!
Can't top that, never seen a chop top 33 b4....
(Justin, I will delete if you find this offensive..)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
