This thread is an attempt to organise who's doing what in reagrds to this NSW trip as many peoples plans have changed.
Original topic thread is here: http://www.skylinesaustralia.com/forums/t176741.html
As far as i'm aware there are three schools of thought on cruising up to NSW.
Group 1 - Those who are doing the Track Day at Winton on Cup Day 6/11/07
Meet Time: Depart 6:30am - 6/11
Meet Place: Donnybrook Shell on the Hume Hwy
1. Snowy
2. Aaron
3. Ant
4. Tony
5. Espo
6. West
Group 2 - Cruise up to Winton on 6/11/07 at a reasonable time to watch the later half of the Winton day and Stay in Wangeratta for the night, before heading to Goulburne on Wed 7/11 about 9:30am (Once Group 3 Arrives)
Meet Time: Approx 12pm on 6/11
1. Chirs + Bec
2. Saff
3. Mav
4. Gadg
5.
Group 3 - Leave Melbourne early on Wed 7/11 to meet up with the Group 1+2 in Wangeratta before continuing onto Goulburn.
Meet Time: 6:00am
1. rexdan
2. Tom
Group 4 - The outcasts who need a can of Ash's HTFU and have pulled out because they are soft.
1. Jack
2. Roy
3. Matt
4. Ferni - you suck
Group 4.5 - If I can get my sh1t sorted i'll come up Wed night.
1. Roy
2. mooabque
https://www.sau.com.au/forums/topic/191670-nsw-track-excursion-cruise-times/
1. Jack
2. Roy
3. Matt
Sticks and stones may break my bones but my fist will surely hurt you! Dont need a can of anything to beat a hack like you...maybe the gods can come up with a can of "Roy's Dose of Reality for Toolish GTR Owners" who think they are going to be quick around EC!!!!!!!!!!!
Group 2 will definatly be going the Hume as apposed to Yarra Glen, as I have discovered there will be plenty of booze buses and TOG cars in and arround Yarra Glen, as they have a meet at the local horse track and apparently it can get rowdy out there. So best to avoid that.
Avoid Booze Bus Check :)
well ive just been royally screwed by my work..... things have gone pear shaped and now my time off has been axed. i am so bloody ropeable right now!
At this stage im out...let me know if i owe any money for the accomidation tho coz i dont wana leave anyone out of pocket.
i still have this little glimmer of hope that if i work my arse off monday and tuesday i mite still be able to hammer it up on wednesday...we'll see...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
