I saw a SII GTS-T loose the back end out around a quiet round-about. The driver had just driven from Buderim to Caboolture, to Caboolture to Ormeau and at 5:30pm from Ormeau to Buderim.
I was tired, two minutes from home :)
Completely misread the road, even though I drive down it twice a day.
Saw a silver R33 Series 2 4-door the other day, first one I've ever seen not in photos, looked sweeeeeet
It didn't happen to have R33 GTR rims by any chance? I haven't seen another silver R33 series 2 sedan getting around Brisbane yet. . . . Was hoping mine was a little unique :D
Not sure, I only saw it from the front as I was driving past it was parked in a carpark with its nose facing the road on (I think) Sherwood rd not sure what suburb that is...corinda?
Yup, that should be mine. Jill works for an accounting firm around there, she drives it to work everyday. Phew. Don't want too many getting around.
I saw that cream coloured r31 yesterday... I laughed for ages.... With the stickers down the side and the v8 style bonnet scoop.... Se flawed off at the lights and it sounded and went like a standard 31. I let him go as there were police in the servo over the road watching him. I saw them smiling too. LOL
Just to re-cap it is the uglyest 31 i have ever seen. I reckon he is like the two guys in the zinger ad where they add body parts made of cardboard to the family car. Except this guy went with the real deal parts.
Hey, Mud this is a Skyline forum buddy, we only talk Nissan 'cause we're tuff. Okay?
Heh, j/k
I saw a series 6-8 RX7, dark green heading north along the bruce highway at Caboolture on Friday. What colour was is Mud?
was a red one
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
