I saw James today in his 'ice green' R33. He was at the lights, down at southport. And I was in the work ute, and it was pi55poring down with rain, and I was lost. Other wise I would have yelled out the window and stuff.
Anyone seen or own the white R33 GTR that gets around down at mooloolaba a bit. Saw it on monday driving near the sunshine plaza when it was raining, sounded pretty good. had a vspec sticker on the boot lid and looked like the brakes on it were pretty big last time i saw it.
I saw a white r33 towing a trailer through mooloolaba yesterday
Also a dark blue R32 gtr parked on buderim-mooloolaba rd the last few days
The dark blue 32 gtr, if it had white work wheels, belongs to someone on here, his usernames Dynamix.
ROFL!! It's true, it's sad but it's soooo true....
Last night in valley saw R33 "6IRLY" parked in valley last night, GTSt with GTR kit, eyelids, lotsa stickers, chameleon paint. Is it just me or is it hellishly brave to park a skyline in the valley on a friday night all night?! I wouldn't be able to relax if I knew my car was out there....
The Lady that owns it works at The Cabaret Club....She is a friend of a friend
Saw afro at Sumner Park today, I was beside you for a bit in the silver 33 sedan.  Was in ordering some new extractors for the mini, the old ones split last night  :) .  And they say GTRs are money pits!
ohhh so that was u,,,cool,,
i waved,at ya, :rofl:
dont worry dale82au hardly anyone sees me either im always out lol...
does anyone know the owner or a blue N/A R33 series one Rego REG45??? owner of that car proved to be a d***khead last nite , was on the M1 cruising along this dude nearly side wiped me off the m1 !! talk about reckless driving i got his plates so the cops have been notified..
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
