Saw two R34's on the way to work on Cav Rd at 12:30. A midnight purple R34 GTT Coupe. The guy flashed his lights at me and I waved. The other one was on the SE freeway going to the city, the other car was on its way out. Couldnt see the plates.
No-one was hurt, theres no damage to my car (or any more then there already was :P) I have a court appearance next month on the charges of racing a 180sx, but I swear I was just accelerating really fast :D
Here, you'll need this...
Spotted a YELLOW R33 series 2 at Hardley Normal Aspley thursday night...parked of course Plate ???84. I was in the Fasta Pasta having dinner as I did not want to go via Aspley as I am now back to the line the only car...too many tools racing on Gympie Road...
Yeah thats me.... Plate "COL-082"
Looks good now hey.... Had a full 3 hour detail yesterday.... FREE
spotted another R33 silver type M near gardencity around 1ish waved owner didnt wave bk .. another was a R32 GTS-T with rego Plates 41 GTR lol that car with those plates where the funniest thing ive been.. young chick driving as well,... stock as rock... another was a a carbon copy of my car 987??? along logan road at 3ish..
spoted a gunmetal 32 gtr on thursday night, followed me outta yatala bp and headed north with me for a while, no personalised plates
seen a gunmetal 33 heading south at least twice now, looks to have a gtr style wing and bbs look wheels.
seen a silver 33 series 2 i think, on the way out to a job site at tamborine at least twice now, he gives me a wave back when i pass him.
There are a few skylines and sylvias getting around up here
I have seen:
white r33 gtr (autobahn owner)
r34 gtr v spec about a month ago parked at the overlander carpark next to a brand spanking wrx
White r33 gts-t with carbon fibre bonnet (blokes name is whitey I think)
silver gts non turbo (dale?? met him nice bloke should look good when he gets the front bar painted)
white 180sx lives beside the first and last takeaway shop
Red gtir pulsar at the church near the sunset IGA
There are many others but I cannot remember
anyone from The Isa ???? come forth.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
