Spotted a dark blue r33 with unpainted full kit popping flames out the exhaust this morning on the gold coast hwy... i think you scared the lady in the car behind you..... it'll look good once its painted...
On my way to work this morning spotted a black 33 GT-R on Collingwood Drv, Collingwood Park, thought about waving but seen the driver was in his own GT-R world, lucky .......
Also spotted a black 34 sedan on the Cunningham H/Way between the Raceview and Yamanto exits, heading outbound.
Thought it was Rhinorebel on centenary Hwy around 3pm, I was going north, he south, too fast to see properly but was silver with Gtr wing.
Yep, was me. You posted first!! Saw your bonnet and knew it was you. :(
spotted a red and a silver r33 go past Rhinorebel and myself outside ppq today around 11:30 - 12 ish
Red one was Bunta!! Why he was on that road when he was supposed to be meeting me at the Regatta is still a question to ponder???
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
