Spotted Sam Irving up the coast at caloundra yesterday morning...
Almost missed him and was in the S15 so I didnt flash or toot as he would not have known who it was, plus he went past before I even knew it was him...
do u own a s15 as well, col??
it has always been my dream to have a s15 and GTR at the same time, but my old one got crashed....
yeah there is, its a r34 gtt coupe,m personal plates are R34, and i think its for sale for 50,000
i dont know if its still for sale but im pretty sure it was around the 50k mark i bought my skyline from the place its up for sale or was...
http://www.thoas.com.au/
500hp with the engine all redone with green pipes and everything
My partner has a "S15 S-GT"
As my car is in pieces atm and hers in on a salary package (you need to do 15,000km's per year min)
So we drive her car 90% of the time...
The garage is for the S15 and the R33... They look hot sitting side by side...
The company hacks get the road out the front... :P
Ive seen you getting around. Was out driving with my boss during work time (we were in a "meeting") and you were turning onto park street in milton, I think you waved? Anyway not sure if it was you, but it was a chick in a pink skyline with a black bonnet, clean paintjob. Nice ride.
I was in a grey 32 GTR /w black bonnet btw.
hmm... im not sure if it was me, my skyline is a pearl pink, if it was me, u would have seen it in fully matt paint, it must have been during the time when i was working on it. Now the paint of my car is half done i still gotto gloss the black parts ,also my boot and wheels are black as well. Anyway so far i havent seen another pink skyline on the road so the chances of it being me are good... well i hope there aren't any other pink skylines around :laugh: hehe
hmm... im not sure if it was me, my skyline is a pearl pink, if it was me, u would have seen it in fully matt paint, it must have been during the time when i was working on it. Now the paint of my car is half done i still gotto gloss the black parts ,also my boot and wheels are black as well. Anyway so far i havent seen another pink skyline on the road so the chances of it being me are good... well i hope there aren't any other pink skylines around :huh: hehe
Actually i spotted a bright pink R32 coupe today in the valley .. pink seat covers and all .. owner wasnt keen on a wave back... :laugh:
Edited by 53XYN
arh dam! not fair! i wanted to be the only pink skyline owner :)
Ah well yours is a distintive R33 so thats a differeance rather a 33 then 32 !..( no 33 Vs 32 war ) just a personal preferance :) unless its a 32 GTR ;):D:D
Edited by 53XYN
I was at car wash, I was already stopped ;) you drove past.
You live local I guess? Got a mate on Browns Plains road with a black R33, not to be confused with the black R33 in Marsden that does skids a fair bit (something PSI plates). Use to stir him up when I worked for dominos driving the echo, go skyline go! lol
I saw a couple cars going the opposite way along the bruce highway... drove to noosa and back, bit hard to wave and didn't pay enough attention to remember, but hello anyway haha.
Spotted Bunta's other car (wine red R33)which has been borrowed by Shanef.
It was parked on the side of the road at the city end of the Centenary Highway near the Toowong Roundabout. It appeared to be empty and sad.
Something obviously went wrong with it.....
Hehe, I waved frantically. Hardly any skylines on the road on new years day!
so that was you
me and mushroom were convoying back from a nye party, and when we parted ways he said he thought he saw you
was travelling down the length of ipswich rd around midday or so
Indeedy, did a compression test on her in the arvo and wasnt good, turns out it blew the headgasket. Put her on the back of a truck, and got her home.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
