Spotted, bout 30mins ago, gunmetal grey R34 Sedan with plates sxc34 with a short arse blonde driving, I thought it was a 9yo child at first, could hardly see her head as she turned in front of me...... :(
Spotted Garry (GAZ33) on Strathpine Road tonight. I was following you up until you turned off towards Brendale.
Ha Ha .. that was you ...
did u notice how I was sticking to the speed limit .. making sure to keep the other car beside me so u couldn't change lanes and pull up beside me. thinking to myself .. this car behind me is itching for a run and I'm not even going to entertain the thought.
didn't even pick the car behind for a Skyline ..
Thanks Chris .. the first person not to mention the "Big Ass Wing" in a spotted Gaz post :ninja:
Today is the day of the black R34 coupe's it seems.
Saw another on my trip home through redcliffe, GTT XXXKAB (not zennon though, just similar plates).
should add, also saw a dark coloured cefiro around the same time I first spotted the 34, just leaving the hornibrook bridge
phatboi spotted on the way home today
blue = purty
shame my blue needs a good clean
i miss washing my car :P
Lol i spotted you and had to tail gate the car infront to wave :laugh:
the rain made my car dirty anyway :( i regret washing my car :ninja:
spotted a maroon 32 on logan road around 1pm today. got a big ass smile from the driver. i am taken, sorry mate.
that may have been me i was on logan road at around 1 and i seen a silver 33 drive past look at me and nod i looked back at u or who ever was driven it and got a nod back but i prob had a smile on my face at the same time... what u mean about this ur taken :( im a dude.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
