FIGJAM i'm good with the wave :3some:
Spotted a "J" plated white R34 on enoggera rd @ 10pm tonight....saw him in the rear view mirror and noticed the unmistakable shape of the headlights and gave him the wave before he came past :spank:
well compared to yours,,,, it looks flogged. and rather shit.
It looked to be a LM to me was the same colour blue and has a similar image frank has in his avatar on the rear quarter panel. Pretty much the same spot where the 40th aniversary badges sit on a 98 model r33
Edited by smurf80
have to go and check it out
there was one down the coast for sale about a year ago, maybe its the same car.
or there was one in sydney
Spotted Dave (DBR33, Rhinorebel) at Virginia Carlovers/Subway/whatever, I was eating a sausage roll from pie karlos when you left :P. Damnit, I want my 33 more now :P
Edited by Hell Fire
Spotted oor34 this morning on newnham rd....your car is sooo hot
haha i saw him on logan rd turning into newnham rd
i waved but got a confused look instead, guess he was sick of the traffic (which was f**king awful this morning)
spotted a silver r33 gtr i think...had sau stickers on the rear quarters. GAZ 99. I was bringing the race car back from mercury after some post race checking. That was from newmarket to everton park along south pine rd.
Edited by r33_racer
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
