Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome :D.  Crazy I say whats going on with browns plains!  cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
Browns Plains is getting huge now, plenty of skylines around...who else on here is from Browns Plains?
It feels like ages since i have been to BP. I might be up that way on the weekend.
Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome . Crazy I say whats going on with browns plains! cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
the black stockos should be good skid wheels :D
was the 33 GTR purple? If so then its brett's (klayman)
there used to be wikid grey 32 getting about the stains, but it think it moved to the coast earlier in the year ;)
the black stockos should be good skid wheels :)
yeh that grey one was siiiik!! :mad:
Zoix - where's bouts is wakerley?...
Saw a silver R33 GTS25T on browns plains rd today bout 4 ish...plates 688HJU.....has the www.skylinesaustralia.com sticker on the back window......no where near centered tho.....
wastes the look of both the 'line AND the sticker
OK Spotted:
Friday night Red 4 door R32 plates were RED32 at Beenleigh Marketplace ~7:15pm
Saturday Morning:
Black R33 Southbound on M1 ~Waitland Street exit (I was nothrbound) ~7:15am
Sliver R33 S2 (Owned was this you looked exactly like your car) Again it was taking the 8 mile plains exit southbound on Gateway (Just before it meets the SE Freeway) ~7:30am
Gunmetal Grey R32 Northbound Bruce Highway between Deception Bay Exit and Burpengary Exit Plates were WIK32 hot HOT chick with white blonde hair, did not even look just stared forward when I waved, not even a glance so she prolly didnt even notice me :) ~8:00am
Wine Red 33 Northbound on gateway just after the first onramp after bridge ~11:30am I was southbound.
End of Report :(
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
