Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome :D.  Crazy I say whats going on with browns plains!  cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
Browns Plains is getting huge now, plenty of skylines around...who else on here is from Browns Plains?
It feels like ages since i have been to BP. I might be up that way on the weekend.
Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome . Crazy I say whats going on with browns plains! cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
the black stockos should be good skid wheels :D
was the 33 GTR purple? If so then its brett's (klayman)
there used to be wikid grey 32 getting about the stains, but it think it moved to the coast earlier in the year ;)
the black stockos should be good skid wheels :)
yeh that grey one was siiiik!! :mad:
Zoix - where's bouts is wakerley?...
Saw a silver R33 GTS25T on browns plains rd today bout 4 ish...plates 688HJU.....has the www.skylinesaustralia.com sticker on the back window......no where near centered tho.....
wastes the look of both the 'line AND the sticker
OK Spotted:
Friday night Red 4 door R32 plates were RED32 at Beenleigh Marketplace ~7:15pm
Saturday Morning:
Black R33 Southbound on M1 ~Waitland Street exit (I was nothrbound) ~7:15am
Sliver R33 S2 (Owned was this you looked exactly like your car) Again it was taking the 8 mile plains exit southbound on Gateway (Just before it meets the SE Freeway) ~7:30am
Gunmetal Grey R32 Northbound Bruce Highway between Deception Bay Exit and Burpengary Exit Plates were WIK32 hot HOT chick with white blonde hair, did not even look just stared forward when I waved, not even a glance so she prolly didnt even notice me :) ~8:00am
Wine Red 33 Northbound on gateway just after the first onramp after bridge ~11:30am I was southbound.
End of Report :(
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
