  • Replies 121
It would be interesting to know if it were a batch or if slide had some one else do the machine work/balance etc at some point?
R33God, you said the motor had a tapy sound or something.. what's oil pressure like? Drop your oil and look for metallic in it.
If there's a tap/knock coming from the motor it is possible for the motor to drop oil pressure and as a result starve the journal bearing turbo as they require considerably more oil than the BB cores.
im looking at the garrett cartridge replacements from rotor master in campbellfield. they do a similar job to slide but with garrett ball bearing cartridge and a hi flowed exhaust housinhg.
olts straight back on coz it uses ur stock turbo
I am not going to speculate what happened.
BUT
If you are looking for pieces of the turbine or whether "something went through it" i would be looking at the intake to the FMIC or the pipes leading to it. When pieces fly off the front compressor, they will usually get stuck at the fmic, they don't go to the exhaust side :D.
Looks like exactly what happened to my turbo
didnt even last 3months or 5tho kms, electronic boost controller so no overboosting...
NOTHING at all went through the turbo
wasnt even booting it when it went bang and didnt make boost...
im still trying to get a refund..........................................................................
One would image that if there loosing blades the wheel is possibly being over sped or surging . I can't say with certainty but many found over the years that compressors with lots of blades like 71mm 8 blade T04's don't like high speed high pressure ratio use .
If in that pic it was a complete blade detached from the compressor then its very likely let go at its root and rubbed on the inside of the housing . I reckon that would do all sorts of nasties balance wise and if it managed to jamb between the wheel and housing that would make itself heard .
Cheers .
Well i got a response from Slide and they basically handballed the problem onto the manufacturer of the turbo for me to sort out....thanks guys!
here is a pic of what became of mine....massive shaft play side to side, nothing in the cooler piping and definitely no overboosting!
oh and I used 8mm speedflow fittings for the oil feed over the recommended drilling of the banjo fitting :S just so there were no excuses
Edited by TazzS13
dam...
wonder if I should sell my hi-flow and go something else now...
goodluck mate, the bad rep these turbos are getting i'd be surprised if you got a buyer.
same with me Tazz.... i sent mine to GCG and got a very interesting report...
i think some legal action might be required?
same thing here.
GCG have printed me out a report on the receipt of the turbo i got rebuilt by them.
R33GOD, let me know how far you get with getting your turbo repaired.
yeah mate, click on the link in my sig for all the details.
heres a hint... Murnane Motors were the company who REALLY built these turbos.
Thanks for setting everyone straight as to where the warranty obligations lay. There has been far too much confusion in this thread about this subject.
Good job.
Cheers.
i have had my slide highflow on my car for about 10 000 ks now,no problem yet!!sorry to hear about the problems people are having with these turbos!
my engine needs a rebuild now anyway,will be putting in some good forged pistons and conrods in!will now maybe consider putting a bigger turbo on,will diffnately be garrett!these problems are not good,but some guys have really good luck with highflows,one of the guys in the rb25 power dyno
section got 263kw at the rear wheels with the same turbo i got from slide,the max oversize one,so it seems weird that these problems are happening to these turbos,maybe the rush that they had with orders at the start of this year made the people that do the turbos make mistakes with the rush,but that should not happen!!i was lucky i got my turbo before the rush!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
