Hay guys!..
Im having trouble getting my ATTESSA to kick in when I want it.
I have heard several schools of thought about this.
a) keep your foot wleded to the floor from enrty to exit. Let it kick in as early as possible, use the AWD grip to propell you past the apex and through the exit.
b) Plant your foot hard after the apex, let it kick in and use the AWD to grip and get you out of the corner.
Any thoughts?
What techniques do you use?
Am I entering the corner with not enough speed for it to kick in?
Am I on the power too late?
Im still new to it.. so I tend to brake too early and dont carry enough speed through the corner as I still have the "fear" factor of "HOLLY SHIT!.. CORNER!".. and then spit chips cos I braked too early.. My biggest fear by far is loading up the rear outside wheel with too much weight/momentum, having it slide out, spinning and hitting something. If it starts to go.. will the VLSD grab, spin the wheels, loose traction and the ATTESSA kick in?
Any advise is much appreciated!
Edited by GTS4WD
https://www.sau.com.au/forums/topic/192625-driving-with-attessa/
impossible to give you driving advice on an internet forum. the best (and safest) way to get a feel for the handling of your car on the limit is on a skidpan at low speed with low grip levels. And you'll have a lot of fun at the same time. or an advanced driver training course with one of the motorsport oriented schools.
Totally agree on doing skidpans and advanced driver training. Great fun and helps you learn about the car. Just getting used to running my car in 4wd mode on the skidpan, normally used it in rwd on the skidpan until now, but it lets you experiment safely and stuff yup without wiping out another car on the road.
Have to agree with skid pan/ track day advice above, no better way to learn than by doing
however I have been giving this ALOT of thought myself
sure i have read on here that more than 15 degrees of steering lock will prevent attesa from kicking in
I think a big part of the "trick" is to look ahead on the track and straighten up asap to aim for the corner exit
rather than hold insane mid corner speed and provoke to much understeer
its all a bit of a balancing act
I could be wrong though
wherever you read that, don't believe it. I can only comment on the R32 version of ATTESSA. They need to be driven much like a rwd car in terms of lines and driving style, but you can be alot more brutal on the accellerater than a similarly powered rwd car. You still need to exercise a little caution in lower gears, or low grip conditions
As everyone said practice in a controlled envioment is the best way. It's hard to say how to drive with ATTESSA, as eveyones car is different, mine had a rooted rear diff so I could nail it through the corners and get no oversteer. But i've got mates with R32 GT-R's with similar power that are a complete handfull cause they have aggressive diff's/rooted center diff.....
And then you have R33/R34 with faster/more aggressive ATTESSA that drives diferently again. So much more nuteral that a R32.
And ATTESSA works of the g-forces not the steering angle, so the higher the cornering force, the less front wheel torque.
So.. ok..
excuse the noob question.. Im just here to learn.. not prove a point..
But how does the ATTESSA system work. I heard so many different stories about steering angle, understeers.
I understand that when the rears loose traction, the fronts kick in with a certain amount of front torque.
Does the ECU control it?
What are the finer points of the system?
Im looking into buying a torque split controler..
Higher G-force the LESS FWT?.. wouldnt it be more?.. to offer more grip and stop it sliding?
depends what G force you're talking about. For high lateral Gs (cornering) you don't want too much front torque because it will induce understeer. once you start sliding there's a reduction in lateral G force and then you want more front torque. For high longitudinal (acceleration) G forces you want more front torque for traction.
ATTESSA uses inputs from a number of sensors including throttle position, steering angle, ABS sensors for road speed and rear wheelspin, and the lateral and longitudinal G sensors, which are the main influence on the system. I doubt you'll find an exact description of the weightings given to each, but you don't need to know exactly how it works. Just the effect it has on the way the car drives, which you'll have to get a feel for. An R32 GTR is very much like driving a rwd car with very good traction.
well the 32 ATTESSA is pretty slow to react, I personally think a controller is essential for better balance. the 33/34 was much better/quciker to react.
probably best to get along to some track days and try some different things, get some advice from people who can drive, like Harry said its really hard to know exactly what is happening without being in the car
I didn't think there was a stearing angle input for ATTESSA? I'm sure the G-Senors are the main drive of ATTESSA, as all the controlers just bend the g-force sensor signal.
looks like you're right. there's no steering input on the wiring diagram to the ETS controller.
Paul Ruzic's controller in the link above looks to be the best one around. love the idea of toggling between 2 maps/settings on the fly (could have one for fast and slow corners, or on the road for wet and dry settings etc), and the data logging capability is kinda cool. And its the only one I know of that offers a number of different base maps rather than just amplifying the G force signals on the factory map.
Edited by hrd-hr30
Absolutely right - steering angle is for the rear wheel steering function. ATESSA in the R32 works from 3 G force sensors, the main one is under the centre console near the handbrake. I race my r32 in tarmac rallying and use a torque split controller - it is essential to be able to dial up appropriate amounts of 4WD for dry and wet situations, like our weekend at Mt Buller last week.
As far as learning to corner - do a John Bowe or Murcotts advanced driving course, then get yourself as many club sprint days as you can at Sandown, Phillip Island or Calder and practice a few different tactics. What works for us is late braking selecting the right gear for exit speed and planting it as you approach the apex of the corner.
I agree with the previous advice about an R32 being much like a rear wheel drive - until you fit a controller.
cheers
Al
lol shaun, they are great at pulling themselves back in once they are sideways, just keep the boot in it is amazing how they recover ;)
ben I don't know those controllers in particular, but all of the g sensors are the same r32 and r33, so if it intercepts that it would work fine
ATTESSA doesn't just works from the G sensors. It also uses ABS sensors, throttle position, and vehicle speed, and has inputs from brake and reverse lights.
i dunno what u blokes r on about.. my r32 atessa kicks in pretty much as soon as i have wheel spin.. whether im turning a big bend.. or an extremely sharp hairpin.. i can have the wheel full lock doin u turns and the fronts kick in as soon as the rears slip...
mines pretty damn fast.. and btw.. for the bloke selling lies about broken centre diffs... they dont have a center diff.. Its a hydraulic pump much like a torque converter with many wet clutches that slip the torque to the front wheels.. not a mechanical centre diff :happy:
Had it been a front diff.. it wouldnt have a variable front/rear ratio the way it does ;)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
