Just want some advice on what i should do for my first engine upgrade on a 1996 R33 gts-t. i was thinking for now purchasing an intercooler and getting it installed. Dont want something too expensive or too cheap, just want something good for now, what brands does anyone recomend. is there something i should do as well or should that be it for now, cheers.
https://www.sau.com.au/forums/topic/194858-intercooler-upgrade/
34 s.m.cooler
apexi safc
front pipe
high flow cat
boost controller
cat back.
in that order
:D
search through here for some diy tips: http://www.skylinesaustralia.com/forums/Tu...IY-FAQ-f57.html
oh and make sure your 100k service is done too
Edited by toffy
im in the process of exactly that atm :D just not in that order.
catback
r34 smic
frontpipe
cat
boost control
safc
well everything except catback and smic is actually gonna go on at once, after i find a good boost guage and the labour cash
Get your exhaust and intake system sorted first.
A larger intercooler and larger diameter piping will result in a drop in response on a stock car.
Bring up the boost a little then think about an intercooler.
Not really needed though for anything under 180-190rwkw.
well i got a 33 as well but i done these mods and i was pulling out on stock boost without the front mount about 180 rwkw....so my advice is to do this:
* full turbo back exhaust system
* a high flowing pod or pannel filter
* clutch if its manual and you do give it a bit
* splitfire coilpacks
* trust/greddy front mount intercooler theses days sell for around $600-$700 with piping
i got a few more mods planned but not as of yet
im in the process of exactly that atm :wave: just not in that order.
catback
r34 smic
frontpipe
cat
boost control
safc
34 s.m.cooler
apexi safc
front pipe
high flow cat
boost controller
cat back.
in that order
DONT FORGET THE DUMP PIPE. www.gktech.com.au has dump pipes for 100$, and fronts with flex pipe for a similar price.
-Ryan
get a hybrid kit for r33. about $650 or so from traders on these forums. Good quality cooler, without the price tag of some of the jap ones. Trust kits are good also and not that expensive. I personally think that a r34 cooler is a bit of a waste of time to be honest. Just do i right from the start and it will give you plenty of head room later on. HPI had an article on modding a 33 gtst including the cooler upgrades, was a couple of issues back. worth looking at.
Thanks guys, the advice was really helpfull
cheers
Unless you are planning on upgrading the factory turbo, I would recommend against a front mount. I made the mistake before, it's not necessary on the stock turbo and you will notice a definate loss in response from the factory setup.
As suggested, an r34 side mount is the way to go.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
