Look i know your going to say use the search or look up at the stickied thread.....
But i dont know enough about the turbos to make a choice... Or be able to compare one turbo to another...
Can guys (and girls) with r33 GTSTs that are making around 275 to 290kws answer the questions below for me...
No real chit chat just answers... plz!
Mods i have are
- Power FC and Controller
- FMIC
- POD
- Apexi Boost Controller
- 3Inch Stainless Steel Exhaust, Turbo Back
- Botsch Fuel Pump
Going to buy some 550cc deautchworx injectors.
Now i just need the turbo...
Turbo Name : not just the serial number plz add garrett etc to
Price :
Modifacations : Mods needed to fit in the same low mount position eg oil lines etc etc
Boost Kicks In : Just roughly when the boost comes on
Supporting Mods : You Have That I dont have
RWKWs / PSI : How many rear wheel kws and at what PSI
Price Including Fitting Etc :
Other : If i have missed anything.
Thanks!
Edited by Adz2332
https://www.sau.com.au/forums/topic/196357-275kw-to-290kw-cars-needed-advice/
You already made a thread about this mate with the same question...?
http://www.skylinesaustralia.com/forums/27...ws-t181715.html
True… but only sorta as I was just told things like buy a GT3076… for me not knowing much what the hell is that! What will it do etc etc etc
i just need some black and white answers so i can compare them to what people have actually used.. just sick of worrying bout this decision just want it done and dusted.. plus any workshops i ask just try and flog the stuff they have lying round. sick of it... this way im hoping to compare apples with apples and finally get a decision.
Turbo - get an HKS GT-RS. Around $2.5k new, $1.5k second hand + fitting costs (new will include kit with all components to fit). If you are paying someone to fit, you're looking at around $300 - $500. Should do 270-280rwkw on 18PSI. Boost from 3k or slightly before.
I have an HKS 2535 which is just a little smaller then the GT-RS, and it boosts from around 2.7k, making 250rwkw on 18 PSI.
Supporting mods
- Suspension needs to be up to the task of putting this power down. If you are still running factory 10 year old suspension, you'd be looking at $1.5k - $2k to go for a Sydneykid setup including fitting.
- You may also require a new clutch - $800+ including fitting. (depends on type, $800 would be for basic button type clutch, twin plate etc will obviously cost much more)
I am managing without a Z32 AFM, but you'll need one if you're pushing past 250rwkw. That's another $300 or so.
Re-tune on power FC ~ $200
Then factory in another 25% for other unexpected breakages or expenses. Then consider the risk that you will blow your engine and require a rebuild.
Edited by Ionos
Did you even read the thread linked then?
It contains all the details, dyno sheets and so on.
If your struggling to understand that and dont think its black and white... then maybe you need to do some more reading :P
There is so much info on this forum if you take the time to look for it.
yer ok mate.. sorry bout the rant.. just struggle to grasp some stuff on here and there is SOOOO many choices!
Would be nice for some one to go here this is the one u need!
Well there you go -
GT-RS - $3000
Injectors - $800
Z32 - $300
Clutch - $800
Suspension - $1500 (optional but highly recommended - what is the point of having all that power if you can't put it down)
Retune - $200
Gtrs will keep you in the "safe" range for a stock bottom end and spool up very quickly. With cams you'll probably get to 265 or so...
it is definately the most sau recommended for an un opened rb25
+1 for GT-RS, however if you wanna go more towards the 290mark, then maybe a HKS 2835. You may need an engine rebuild some time after pushing this type of power. I'm limiting myself to 270@wheels for the stock bottem end for the time being.
If you have a friendly tune and your engine is generally healthy, your unopened motor should be fine pushing out well into the 260+rwkw's. HKS GT2835proS kit! The GT-RS in my opinion will struggle to put out your aimed power without cams and testing the boost on a stock motor. The 2835 will get you up there at around 1.1bar, and as mentioned if your motor is healthy and your tune is good then it should be fine, especially if its just a street car.
price wise, its been too long since i bought mine so make a few calls..
i think if im looking at the right one the price for the HKS GT2835proS kit from neugen was around $2200 that sound about right?
That price is for the turbo only, you would need to get oil, water lines, gaskets, etc all locally.
If you want the full kit, you're looking at $2900.
http://www.nengun.com/hks/turbo-kit-gt-sports-pro
ahhh yep cheers for that.. bloody hell cant even look up the turbo right!! grrr... might just hiflow and be happy wid 250 i think.. all to hard!! would i see mayb 260??? whats the max for a hiflow??? response? etc
Don't have on myself, but my understanding is that the hi-flow is about the same as the 2535, which means 240-250rwkw, or 250-260rwkw with cams. Response would be still good, a little laggier then standard which is mainly due to the steel wheels being heavier then the standard ceramic/nylon combination.
ahhh bum dont wanna shell out for cams.... grrrr
Forgive my ignorance, but why would you hiflow when you can get a new KKR/Biagio/hypergear etc for sub $1000.
I know, I know, a hiflow is nearly a new turbo, but its not ALL new, and it is still an older pre '00 design [only in little ways I admit] but you can buy the new turbo, sell the old std unit, and come away with a brand new one for say $5-600.
The age of the hiflow is dead!!! It happened, it was good while it lasted, but there are better options out there now, its time to move on.....
BTW I've got a 3076 WG [brought it off Slide], so I'm not saying go and do this or buy that, just posing the question.
you need to decide exactly what you want. do you really want 270-290 rwkw or is this just a fat sounding number?
if you want virtually stock response and something that is quick to drive around on the street (and cheap) the GCG hi-flow or GT-RS is the no brainer as they are bolt-on. cams will give you another 15-25kw but may shift the boost threshold down lower so the turbo should come on a little earlier which is a whole lot more than it sounds in practice. 250-270rwkw is about where it will top out.
HKS 2835ProS more money more up top less down low (by a small fraction) SLY33 is correct (again imo) the GT-RS will struggle up top.
GT3071 60mm turbine 56 trim comp similar story but a bit of stuffing around getting all the bits together, if this is not your strong suit then the HKS kit is worth paying a premium for. these should make the midrange of your target.
HKS 3037 or GT30 (GT3076 in so many guises just ask 'the mafia') same story as above but shift your expectations higher more ponies less down low. HKS more cost but bolt on kit. these will exceed your target.
the more you want the more it costs (often exponential).
i bet you will be happy with a GT-RS and good tuning.
Edited by wolverine
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
