hey there guys
just wanted to share my experience with everyone when i finally brought my r32 gtst 10 months ago
since then what has happen to my 32 is my front driver side fender has been reverse into as it was parked at
the gym, leaving me the bill, as the driver did a hit and run, next to follow that was my car was parked at a friends house slept
overnight and came out the next morning to find that my driver side door had been reverse into, damaged was to great so
had to purchase a new door and respray the whole driver side, yet again leaving me with the bill. After getting my car back in
perfect working order i was involve in a accident today. Was driving on the highway and the driver of another car signal into my
lane without looking at his blind spot and hit my whole driver side (wat luck huh?) so now i need a new side blinker and
another respray on the driver side. l
https://www.sau.com.au/forums/topic/196876-is-my-r32-curse/
That sucks man did the guy that hit you today have insurance at least? Hope things go better for you soon, theirs nothing worse then constant problems with your pride and joy, makes you so depressed.
Edited by Dave69001
https://www.sau.com.au/forums/topic/196876-is-my-r32-curse/#findComment-3522630
yeh we have a cursed black car too, 350z, its had 5 good hits in 4 years, every panel has been done, none were our fault. Most recently a jeep turned into us in a corner, I stopped when he hit me but he kept driving - so he scraped the front bumper, drivers side guard, drivers door, drivers rear guard and rear bumper
https://www.sau.com.au/forums/topic/196876-is-my-r32-curse/#findComment-3522792
yea this is pretty much what has happened to me aswell. black r32 gtst. the front bonnet it damaged and front bar, reverse lights are broken from gettin bumped in the ass, back right panal bumped, number of dents in door from retarded people that cant open doors proply.
i think i might have to get a really touchy alarm and just run out every time
https://www.sau.com.au/forums/topic/196876-is-my-r32-curse/#findComment-3527291
Wow mine must be the only lucky black car then.
The only problem I have had is clutch went.. Stock clutch my fault because I was pushing it on the skidpans, your usually old worn parts that need to be replaced over time.. And my gearbox needs a reco but thats another story.
Ive had my car for nearly 2 years now.
https://www.sau.com.au/forums/topic/196876-is-my-r32-curse/#findComment-3528069
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
