Just wondering if anyone can think of cars that are both pretty (to keep the girl happy) and reasonably quick (to keep me happy)
Criteria:
Under $20,000
should have 4 seats
reasonable sized boot
2 door's
comfy seats
I have suggested and she has said no:
Any skylines (I had a bit of a cry, and still no...)
Silvia's / 200sx
Alfa Romeo GTV (both types)
Toyota MR2
Soarers
BMW's
Honda civic / prelude / integra (getting desperate)
We have driven all of these and they have failed for reasons ranging firm ride to the windscreen isn't big enough...
Things she likes the look of but we havnt driven yet:
180sx (she doesnt know they are built on the same base as a silvia - crossing my fingers)
supra
300zx
FTO
Is there anything else in the $20k range that I am forgetting? We only have an old lancer at the moment (her car) so it shouldnt be this difficult to sell her the idea of a decent car!
Thanks for your help :dry:
https://www.sau.com.au/forums/topic/197802-ideas-for-next-car/
  • Replies 42
fto - i find them to be crappy when compared to the likes of supras and skylines
20k - u can probably get a 1993 twin turbo supra - but the condition may not be as good
personally id go for the supra
another car she can look at is the corolla levin - the 2 door jap spec one.....i forget what its exact name is.....
The guy wants a car with 2 door guys.
I wouldn't recommend the supra if you're planning on having children or have them already. I wouldn't call the things at the back, seats or that small hole in the rear, a boot. Forget supra if you're looking at having a family at some stage.
There's not much other 2 door cars I can think of that's 'good'.
If you went 4 doors as well. I would go for the A4 or JZX90 mark II or JZX100 chaser.
Good luck!
Edited by adam-__-
Well why a 2 door...
That and most of those cars don't have a boot anyway.
Split the money, $10k gets you an R32, $10k gets her an astra. Done and done. Then you have 8-10 seats, and 2 boots!
Edited by dangerous_daveo
thats great thinking there.
grow a set of nuts and buy the car you want?
Tell her to get back to the kitchen where she belongs.
Ask what she would like, listen patiently to her reasons then buy what you want anyway and tell her to have a coke and a smile and shut the f**k up
these people all make sense!
saying that, I would go the Supra if I was pussy whipped :)
Edited by Nexus9
+1 FOR A STAGEA
My missus was dark at me for not buying her a corolla (!) but after she drove it, she reckons it was the first car she ever came emotionally attached to. They go pretty well when stock (well, compared to a commonwhore of foulcan wagon anyway) you have all the same mod options of a skyline, about 10 times the interior room, and the NVH and build quality far surpass any other wagon I have ever driven.
Having said that, the Audi A3 1.8t is a horn of a car
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
