Hmm turns out i actually don't have fog lights either :D. I thought i did because it said so in my car manual, but i checked recently and it turns out i don't.
Anyway, i think my parking lights are T10's and i have an R33 Series 1?
  • 4 weeks later...
  • 3 weeks later...
wot about R34 xenon headlights... anyone know wot type of bulb they are??
R34 Headlight bulbs are
Parkers: T10
Low Beam: H1
High Beam: GE 9011
Note GE 9011's were discontinued about 18 months ago,they were replaced by Toshiba 9011"s but you can also use any 9005 bulb by filing a bit off one of the tabs.
Both H1 and 9005 bulbs are as cheap as chips on everyone's favourite auction site.about $18.00 a pair including postage
mate can you take a pic of the front bar indicators next time you take em out ..never seen them with fog lights in them on a series 1 before...mine just have a slot for the parkers..wouldnt mind chasing up a set..
Edited by thizzle
Parkers: T10
Low Beam: H1
High Beam: GE 9011
If you can get a hold of the 9011's use those as they are the brightest halogen bulbs you can get.
A comparison:
http://hirheadlights.com/stats.htm
And some info on 9011's
  • 3 months later...
If anyone is interested im putting together an LED kit for the R33 series 2 (maybe more models if these become popular)
Basically replacing all of the exterior bulbs with LEDs.
Fog lights
Parker lights
Front, side and rear indicators
LED indicator flasher unit (so no more fast flashing indicators)
Reverse lights
As i already have the aftermarket LED tail lights in i wont be getting LEDs for the stop lights. I did however put LED bulbs in when i had the stock tail lights in and they looked crap.
Ill post some pics in a few weeks.
  • 3 months later...
  • 4 months later...
cheers for the help ppls
i moved the washer bottle to the side, and managed to get it out, and back in, using long nose pliers.
here's my contribution to your thread :thumbsup:
the parker bulb type, and holder. R33
hey just asking how did u managed to put the new light in??? I got a series 2 R33 and it is very tough to put it back...did u twist it or something?? mine is a 15mm wedge btw...so its a big bigger
  • 1 month later...
.. And be careful even with 'so-called' white LEDs. My car had DAN-666 'white' LEDs which when I was forced through a Regency defect inspection for my exhaust, they added my 'too blue parkers' to the list of things to the *new* defect list. Awesome.
Yep for the reason shown below, something that is 'less yellow' appears 'more blue' even though it is a spectrally a definate pure white (5000k to be exact) it is 'less yellow'
than a 3000K tungsten bulb.
A good example is to put the white LED next to a BLUE one, it actually appears 'more yellow' but for the clowns at Regency 'perecption is reality'
Edited by 666DAN
  • 4 weeks later...
Hi, does anyone know if you can upgrade the globes on the Driving lights for an R33 series 2. I see from this thread they appear to be 55W H3's and I know that for the headlights (being plastic) you shouldn't go above the stock 55w bulbs, but does the same apply for thre driving lights? (are these lenses also plastic?)
They are fog lights mate. And are pretty much illegal to use in 90% of driving conditions. Which is why i put an SMD LED cluster bulb in there, so now they are driving lights.
I could argue the point to the police if i get pulled over, i probably wont win seeing how the rest of the car breaks nearly every rule in the book ;)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
