  • Replies 3.9k
Posted Images
no going to Malaysia or Singapore is cheaper than going to Melbourne. I was looking into the for the GT500 racing to see the R35 race. about $1500 for 6 days including airfares and hotels http://www.skylinesaustralia.com/forums/Su...l&hl=sepang
definately couldn't spend 6 nights in melbourne and see the gp for $1500.
depend where you stay and who you know to get tickets from.
speaking to David Richards the other day they are still not happy they are being stopped from running the ex McLaren Chassis. Williams are still the biggest campaigners against Prodrive. But i'm guessing being Berrnie which ever side has the most money will get their way
for sure. 6 nights in melbourne probably costs me $1500 in cans alone!
Gees if I had a dollar for everytime a GP driver used the expression "for sure" or maximum...
Problem is that for the majority of them English is not their first languge & they get tutored in what to say by the PR people. Which means you either get a Kimi (pick one) saying nothing or generic gobshite instructed by the PR people.
Oh and since when does "top 11 finish" sound better than 11th?
haha me and my mate love it when they use 'for sure'
The best was a combo by either Kimi or it might've been Massa...
"I think so for sure we will be competitive" or something along those lines....Massa uses for sure HEAPS and he speaks like 8 languages...
Well atleast there is some more sponsorship stickers on it this year round. Hopefully the $'s are there to back it up. They took a bath financially a couple years ago when BMW did the dirty on them. I don't know why Toyota don't start writing some cheques for Frank. He hoses their factory team on far fewer dollars. Give him a few more & "factory" status (Like Renault used to do with Lotus) and he could get more sponsorship still.
Car looks good & the lap times are good. Drivers are quality. Everything looks to be in place for another improved year for the boys from Grove. :D
If this keeps up I may yet have to commit to some Nakajima merchandise. :thumbsup:
good stuff
so i know what the hit is going to be in 2011, roughly what has it all set you back?
1k for tickets.
1k for flights.
Staying with a mate of mine from boarding school who's family live in Singapore, his old man works on the offshore rigs so we got a roof over our heads... :thumbsup:
Plus accomodation for the GP weekend was massively overpriced... Daylight fcking robbery...
Edited by Marco-R34GTT
I was only talking to a friend in Singapore the other day. They all still work and live in Bugis with out Singapore office looking out over part of the track. The problem is ticket prices as could probably get work to hook me uyp with airfares if i do a 2-3 month stint over there. Plus, so many funny places to go and drink
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
