Yeah I do workout at home, and I don't smell that bad, it's more that over time the shirts build up a bit of odor.
Singlets are the go for summer.
Plus I'm thinking of this doubling as my running shirt and in the warmer weather I wear a shirt to protect me from sunburn (milky bar kid).
My 2XU tights give me the confidence to do all the things I want to do, like horseriding and vacuuming and preparing sandwiches, without those embarrassing interruptions from mother nature.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
I don't run. I generally wear them on leg days.
Self massage/massage should be apart of everyone's routine IMO.
Markos two questions.
1) Can you show me what you consider good bent row form.
2) Given the rom issues i'm having with my ankle and how it affects my squat mechanics, do you see issue with me using a 10mm or so board under my heels?
Okay, I'm rowing now, see how I stay down and pull the bar to my belly not my chest, perfect form, I have 140kg on the bar and I'm knocking out 8's
I recommend the heel, but proper footwear (heeled lifting shoe) is much better, around $120
  • Like 1
went to the premiere of Pain and Gain at the local cinema last night, nearly the entire audience was the swole guys from the gym who also lift 5 days a week + the "natty" bodybuilding crew from the other gym. Good movie, was surprised to see compound movements featured a lot, 10/10 lols
I loved pain and gain thought it was an awesome movie
it came out in the US months ago - I chose to wait for it at the cinema here rather than watch a crappy cam version.
weighed myself again, still at the same point as the last 3 weeks or so, given recent diet and training changes I'll check again in a few more weeks!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
