There's a pin-loaded seated leg press machine thingy I've used a couple of times, but unfortunately even on the max weight setting I still manage sets of 12+ reps lol
I like doing single-leg incline press with ~100kg loaded up after whatever my main leg exercise was (squats or proper leg press).
Fortunately for me, our leg presses use the old thin holed 25kg plates, which only fit on that and the smith machine. So our plates stay in the area or on the leg press itself...usually find 8 plates already on there thanks to a lazy individual.
not sure if it's been posted yet but:
http://www.news.com.au/lifestyle/health/remove-bar-from-windpipe-then-squat-guy-faints-in-gym-fail/story-fneuzle5-1226725940365
guy faints squatting 180kg (vid inside link)
Think we've all seen this before...
Honestly, any gym where guys are trying to squat probably 2x or more of their body weight on a front squat is going to have the potential for failure, nothing special about it being in Markos gym, other than if it was a commercial gym it would've been 120kg instead.
When I thought I'd badly done my back I fully dropped the bar on the safeties hard core, there was just no video.
Sometimes we will fail.
You know what else helps squats and deads?
I started a new thread on Marty and put up his NEW video after I started getting calls from news networks.
This is going to get bigger.
Funny how nobody wants to know about his 290kg deadlift but theyre all over a missed front squat lol
I'm surprised you're not getting told off for making your lifters do unsafe things like squats LOL
This..
Imagine that bloke from L33sh's Gym reaction if someone tried that at his gym lol He would of had a coronary
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
