Lol turn 1 and the last turn at PI definitely is a highlight :D ...but I'd have to rate the corner going over Lukie heights as a bit of a fav.....left hander over a crest. As you go over the crest you feel the whole car unweight and it just drifts over to the right....you have to steer back onto the left hand side of the road and break hard for the 2nd gear tight right hander.
over the crest on the long wang! haha (Vic guys will know what I'm on about)... so much fun
seriously tho, turn 1 at PI scared me, but but turn 2 is far more technical and harder to perfect... turn 1 is more like dab the brakes, grow some balls, tip it in and hold on... turn 2 and a couple of the others I'm not sure where to apex so I find much harder to go fast through
long wang is always fun, I like the short wang though when you come out of the left hander, get on the gas, get a bit taily and up that "jump/hump" part!! awesome!!
The texi at sutton road with the big dipper and going over the little jump and having your stomach go from normal to up in your throat is awesome!! lol
flip flop at OP is pretty good. you know you have done the last 2 corners well if you are going fast enough that you want to lift off. plus there is so much road there now. track/ripple strip/concrete/more concrete/dirt. the only part you really dont want tyres on is the ripple strip. other than that just pick a line, hold the throttle flat and enjoy. it hammers the underside and suspension a bit though. :D
love coming off the bridge too. lots of track there to use also, but it's very dirty if you get too wide too early. apart from that it's a great corner.
4 and 5 at eastern creek is pretty good. you come down into 4 off the hill and it's one of those corners that can actually be taken pretty rapidly. then you need to be instantly back on the right side to turn in for 5.
turn 1 at eastern creek is good for the odd brown moment too but so many people I know have stuck it into the wall there with nasty results that kind of takes the fun out a bit. wish they would move that inside wall as it's very close to the track and claims many a fine car.
at wakefield I quite like the turn coming onto the back straight. can be tricky to time just right and is pretty important for a run down the back straight towards the last turn onto the front straight.
I going to assume you are refering to PS games.
More like watching F1 and Champcar, but when I posted it I didn't quite read through teh thread...
So yeah.. +1 for teh n00b...
Hayshed at PI scares me since I can't do it flat anymore. But getting through that and coming over the top of Lukies is super.
3-5 at Wakefield is heaps of fun - so is the esses into sweeper at Barbagallo.
And coming over the hill at DECA is crazy in my car - especially if there is no chicane there!
And finally - the time we got to do the Thunderdome @ Calder as part of the GP Circuit was completely crazy.
I can't make up my mid;
Kink before the chase on Conrod at 275+ kph, flat out, no lift off, that's exhilarating
OR
McPhillamy, it's blind. so you turn in from memory
Cheers
Gary
Fish hook in the wet is "fun" :(
What times were you doing Brad?
Going to the SSCC sprint march 2? Its my bday so I doubt I'll make it :D
South circuit was consiatanly doing 47's on sunday with a borrowed timer, but its got alot more in it once I sort out the suspension issue. Straight line speed was phenominal. Just felt like a drift car through a couple of turns.
Yeah im taking it back to oran park on sunday this week for a GP day to get suspension hopefully sorted.
Back on dyno the week after for some more boost.
Then wakefield on the 23rd for our circuit day
And with any luck ill have everything iorned out for the begining of the series in march.
Totally agree. you question yourself and think should I shouldnt I then change your mind twice before holding it down hard!
Edited by Risking
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
