Snowy and I did a small cool-wall update the other day, but need to add some more new cars.
I am open to recommendations and suggestions!
J
* edit - list of cars to be added to the Cool Wall...
Datsun GT-R
Maserati Gran Turismo
Ferrari F430 Scuderia
Ascari A10
Zonda
ZR 1
Weismann
Fisker Taramonto (coach built MB SL)
Tesla, Veyron and Phantom are there already
https://www.sau.com.au/forums/topic/205142-help-me-update-my-cool-wall/
Am I being too obvious when I say....the new GT-R in Subzero
Maserati Grand Turismo...Cool
saw one of these yesterday... assuming the guy down the road with the warehouse filled with nice cars has one... looked awesome.
What about the Tesla Roadster... because clarkson hates them to death, electric power!
or is that one i can see already on there under supercool?
Hate to say it, but the GTS RS, Zonda and the GT40 should'nt be in the Sub Zero area... they are just cool :thumbsup:
Where is the Atom??
Oh and a P2 in the cool section...it's got too much electronic trickery to be any higher
cool cars
F40 simply because theres no bullshit, just a race car
H1 hummer coz its no bullshit, its just tough
Lambo Muira coz its quite possibly the most beautiful car ever created
VL turbo - dose it ulehhhh!!!!
cars that earned their right
mini cooper - where small cars began, and why they are so popular today
volkswagen beetle - car for the people
300SL gullwing - the ORIGINAL supercar
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
