Anyone know why heaps of Grp A and C cars are missing from muscle car masters this year? Was out there today and heaps weren't running or at the even, including the Winfield 32, and the 31. But the Bluebird and GIO cars were there. VL's were missing, hardly any Sierra's. Something must have gone down as its pretty much the premier event for these cars.
The Winfield car is not there simply because Terry has had too much on recently. I cannot speak for the rest of the missing entrants but as you know we are all self funded and after the Phillips Island Classics followed closely by the Albert part F1 support races some of the guys may have had to pull out due to funds.....most of us pick and chose events months out and budget for it........i'm sure they would all love to do every event.
Like everyone I else am missing the scream of an R31 the most! :(
Just an FYI also....There is a bit of a change going on throughout the A & C category atm. For example the GIO car and a couple of others were going to be pulled from MCM as well by the owners due to the risk's being taken by racing against certain other drivers who refuse to pull there heads in and stop running into each other......I actually think that some of these people think that the public are coming out to see them and not the cars! :domokun: Anyway the problem may have been resolved with a couple of letters and phone calls to Cams and MCM!
Rubb'ns racing I agree.......with replaceable cars though!
Went out to Eastern Creek on Sunday and took some snaps.
Peter Jackson Sierra
http://chrisslong.tumblr.com/image/30790028900
HRT VL Commodore
http://chrisslong.tumblr.com/image/30790000216
Grp.C Nissan Bluebird
http://chrisslong.tumblr.com/image/30789962203
GIO Nissan GTR and Peter Jackson Sierra
http://chrisslong.tumblr.com/image/30789875375
GIO GTR
http://chrisslong.tumblr.com/image/30789848222
Im a keen amateur photography so please let me know what you think of the pics guys.
I'd much rather pay money to watch a round of Grp A/C cars than a V8 supercar round. Great to watch. Love the sound of the E30 M3.
  • 8 months later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
Might just mention. For the first time in 20 odd years we have moved away from the Nissan's. We have sold the GIO gtr to Terry Lawlor.
But in a deal we have also settled and I will now be campaigning the 1992 Caltex Sierra. Should be an interesting experiance as I have have driven most of the GMS cars but never a Sierra.
Might have to tighten my nuts a little more coming out of the corners!!!
anyway.....just an update!
P.S. Do you approve of the move Roy! :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
