Hey all,
I was told the Power fc add on to control boost was S**T and better options were avaliable for around $350. And the Greddy Profec B Spec 2 was an option. Whats it like? thoughts? any better options around for the price? to go into a GTR R33 around 290kws.
What other units are there? Better at holding boost?
What kws are you running with them?
Cheers
Edited by Adz2332
https://www.sau.com.au/forums/topic/205508-boost-controlers/
I would personally just get a turbo tech ball bearing controller for $22.00 Does exactly the same thing as those electronic boost controllers. If you want 2 stage, just hook up an electronic valve to it, easy.
I would not be trusting a $22 ebay bleed valve to adequately control boost on a modified R33 GTR.
Hey all,
Cheers
Adam, with all due respect, you need to stop listening to whoever it is that keeps feeding you this crap.
no me either! lol
Two people have told me the apexi boost thing is S**T. one being a trader and the second being my tuner... The tuner said if im paying that much you might as well have a look and ask around as there is better around
Edited by Adz2332
profec B II is about the best you will get for that money. go up to say $500 though and there are lots more options open to you.
I have a profec B II in the GTR and no problems with it.
GIZZMO MSiBC best bang for buck, good enough to take out dspeeds boost controller choice... and it is run on their 1000hp GTR, i use alot of these things for guys who want killer boost control but on a budget..... the processor used in the MSIBC is bigger than that in the average microtech :/
http://www.gizzmoelectronics.com/Product_MSIBC.html
the powerfc kit has a distinct advantage over the other units in that it enables boost correction on the maps
so it can back out timing, add in extra injection based on boost levels and so forth (if setup correctly)
it also is displayed on the hand controller
but i dont see why the pfc boost kit wont work - a fair few people use it
at the end of the day though and im a huge PFC fan it is very basic and fails to perform anywhere as good as a BLITZ dual solenoid boost controller and both cost about the same.... the lack of gain and usefull boost drop compesation make it one of the last choices on my list.
how bout the avcr?
its pretty to look at and ive owned about 4 over the years, not even in the same league as a BLITZ DSBC.
attached is a dyno graph of a BLITZ DSBC controlling twin turbos set at 15.5psi and fairly low gain.. it is spot on except for a smal dip at the start caused by wheelspin but even then it did not spike once it gained traction...
i cant find the graph for 18psi but the boost line was just as flat.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
