Black stock Stagea on the PRE past Mawson Lakes at around 4.15
Wingless 34 that appeared to be completely in primer on Military Rd at Grange at around 4.30
Maroon 33 gtst on Marlborough St at Henley at around 4.30
heslo, josh (jap star) and glen's mx5 off corkscrew rd :thumbsup:
silver stag, front lip, cr kais and XX plates, next to / followed me down greenhill, portrush and a bit of fullarton road after 5 today
and martin in the GTS2 on south road about 5:30, did you like my "exit, stage right?" :ph34r:
heslo, josh (jap star) and glen's mx5 off corkscrew rd :nyaanyaa:
and martin in the GTS2 on south road about 5:30, did you like my "exit, stage right?" :)
ha yeah I saw what you did there!! Nice.
Saw a R34 being pulled over on Magill road about 11pm Wed night, just outside the tower hotel.
Marked police car pulled him over, then 3 undercovered cops cars decided to box him in. looked like some serious shit. but then they all drove away?
Anyone on here?
Silver r34 gtr cleanest 34 iv ever seen perfectly modded saw it on panalatinga road yesterday waiting to turn right.
That was me on my way to Steve Knights, after picking up my castor rods. Carbon bonnet with TE37's sound about right?
By the way its for sale :).
Were you in the white 33 that screamed past me?
Edited by Adelaideprosound
spotted a red series 3 r31 yesterday morning around 9:30 on the corner of pooraka maccas (say that 10 times)
dude had massive amounts of turbo flutter and he wasnt even gunning it that hard... thought it was a VLT till i actually saw it
-D
Spotted R32/34 (32 rear with R34 front) primed grey without any color. Also spotted white R33 behind me coming back from Lonsdale on Lonsdale highway, White R34 on Anzac highway and white Stagea on Brighton road.
May have spotted Stol at the panatalinga / southern expressway intersecion yesterday morning around 10.30. Waiting to turn either onto the expressway or south road..
Also a white S13 with no front bar driving up through the hills near cherry gardens yesterday.. Defect waiting to happen..
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
