saw a blue stag (stg 025?) on saturday i beleive from memory around 1030ish turning onto reynell road from byards road, was being followed by a 180sx?
shortly after saw a white stag at flagstaff hill/aberfoyle park skate park (slo 034) ???
later on in the day mid arvo also spotted a r34 4 door in white (raw 034) turning onto sunnymead drive then saw a silver r33 with xx plates then a maroon/red 33 staight after the silver one with plates (rpm 033)
spotted today was the same silver r33 with xx plates at aberfoyle park shopping centre/chicken hub (sau stickers on rear quarter window were also a dead give away) round 1230pm
i beleive a decent sighting in my daily driver for one weekend.
Spotted Silver 33 with plate HER RB at Briens road/Hampstead Road intersection yesterday. It looked like it was a very clean car :) oh and a black 350GT on Bridge road this afternoon :)
Saw a few today,
Black R34 with a kit had a female driver around 7:45am on goodwood rd. Also in the afternoon saw a white R34 GTR with gold wheels? on fisher street around 3.30pm, nice looking white 33 GTST on the back of a tow truck too, had a GTR spoiler and front bar/lip, goodwood rd, around 3:45pm. Black 33 with some deep dish wheels female driver as well, looked tough on main rd, coro valley.
silver 33 was me both times, think I remember seeing you on sunnymeade...
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
