Roy, i have been toying with the idea of removing mine. I see that it is removed on n1 gtr's and alot of track cars. I dont really think having it is much of a bonus and probably a negative if you slide off the track and any great speed and need to stop?
Edited by 2630GTS
Here here, second that. For purely circuit I'd probably remove it.
I would never have crashed mine (on the street) if ABS was de-activated, but for 99% of the time would still prefer it.
IMO, 32 era abs is too slow acting and only 3 channel, therefore you'd be better off either removing it or upgrading it to something 4 channel and more modern, IF it's a circuit car.
Cant say that i have ever felt mine kick in, grabbed the odd front tyre every now and again but never felt the pulsing i would associate with ABS activating. maybe a problem with it?
Well on a bumpy circuit it will kick in - mine does at my local circuit quite alot.
Yes it is a bit slow acting & yes it is a bit heavy but I'd rather that than a flat spotted tyre.
Ok a quick list of parts and their approx weight from what has been found within posts on SAU.
this list is only the weight removed not replaced with any other items yet as stuff like exhaust needs to be replace with a difference system to get nett gain
2 x Door window, electric motor and guide for glass, switch, door card = 24kg
HICAS removal, soliniods, pipes, etc = 25kg
Fuel tank = 12kg
Steel exhaust system =15kg
Rear seat =6kg
Passenger front seat =12kg
A/C system =10kg
heater core, ducts and fans =10kg
Standard prop shaft =15kg
sound proofing ( tar like crap ) =8kg
carpet and underlay ( best guess ) =7kg
sound system AC control =10kg
interior trim ( best guess ) =8kg
Feel free to correct any of these or add some more to the list
Duncan is sure is a whole lot of work, and the sound proofing is a right pain in the a#@&.
still i have noted that i can feel the benifit of the weight off the car. Also found that the 18" wheels are lighter than stock, same with the brakes with 2 piece rotors.
about 160 + kg
will look into the added weight later this week
Looking at that list, really all you can loose on your typical street/track car like mine
would be around 100-120kg's after taking all i can out and putting all the saftey/uprated items in.
I'll get home tonite and weigh up all my aftermarket parts i have off at the current time.
cooler
drivers seat
exhaust
Bonnet
Headlight intake
Will update this in a few hours.
skylle I'm pretty sure the only difference is the later doors have side intrusion bars in them. If your gtr was imported and complied they added intrusion bars if it was early model so there is really no difference.
has anyone tried plastic windows? they are stated to be 1/4 of the weight of the automotive glass. and it can be legal on s.a roads(not sure on the others, just found a link. they legal in vic ?)
http://www.cityplastics.com.au/automotive.html <-- link
anyone know the stock weight of the front or rear windscreen?
rear quarter windows are only 1kg each or less so not worth replacing
Edited by Dan_J
im about to fit a lexan passengers window and remove the drivers (will use a net instead) You have to retain a glass windscreen for saftey in most events.
By the time you remove the glass, motor, regulator and wiring assosiated with it there can be decent savings per door.
Ive also removed all the old steel lines this week and replaced with alluminium/ speed flow fittings.
The steel ones are really not that heavy but the alloy is lighter and its fresh.
Andrew whilst you not using that headlight can I borrow it and make a mould? I want to make a carbon item but cant find a decent one to mould it from.
surely most plastic windscreens for automotive purposes are safe :) and plastic would be saving you a pretty penny over lexan.
yer but skyline windows are hard to fit due to a frameless door and they have to be made out of 5mm material and are thermo formed to get correct curve.
easy to form them just put in boiling water for a few minutes then clamp it to the original glass to cool. would be 15 or more kgs in weight saving from all glass being replaced
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
