if im not in a hurry i normally wait for the oil pressure to hit normal. most morning id run out side start the car up set the turbo timer to 10 mins then arm the alarm and run back in lol by the time im dressed shes nice and warm and good to go. if im in a hurry id get it wait for 1 min start driving but wont hit boost and like others say keep revs below 3000rpm
idle ur car is bad for ur engine? cant be??
Idling is not bad for your motor. Running cold is.
So (within reason) the quicker it gets up to its correct operating temperature the less wear you will get.
So sitting in the driveway for 5 minutes whilst the thing sits there running cold is bad for the motor & will undoubtedly annoy the fk out of your neighbours.
i agree, on a cold morning just letting the car sit and idle till it warms up can take much much longer than if you just drive it slow, especially if the car doesn't get kept in a closed off garage.
and also the time it takes depends on your thermostat. if your thermostat is stuffed and not closing properly, letting it idle up to temp could take an hour on a very cold morning, which isn't good for the motor at all.
when i drive to work in the morning, by the time i have been sitting at intersections, etc, the car is usually up to temp in less than 1km, and that would be no more than 3 or 4 mins. although my skyline used to take a touch longer to come up to temp.
Yeah it's a trade off between running your car cold on idle for 5mins, or driving your car cold under 3000rpm for 2mins...
Personally i drive below 3000rpm to warm mine up... and never put my foot into it until the oil temp has got above 70.
yep, very bad idea to let the car sit at cold idling for 5 mins. apart from being bad for the engine it also means that you are not getting any temp into your gearbox, diffs, brakes or clutch. so when you do finally set off your engine will be up to temp but nothing else will be.
imo the best idea is start car. take your time getting comfy etc and you should be edging out of the garage about 30 seconds after you started the car. I am the same as ferni in that I just drive it normally along (minimal boost, revs under about 3,000) until the oil temp passes 70. then you can have some fun if you want, but hold off on any real 'fangining' until oil temp is 75+. :thumbsup:
remote start while i'm brushing my teeth...
when i get in a minute later the climate control is just right, dvd is playing, cars starting to get warm and the back windscreen is demisted.
/bling
It's even more important to warm the car a little if you're running forged pistons. I usually finish breakfast, start car, brush teeth then drive away below 3k with gentle acceleration.
I read somewhere that 90% of engine wear occurs in the first 11 mins, how true this is im not sure. But judging by how much longer oil temp takes to increase compared to water temp its certainly increased my level of engine sympathy from now on...
Driving at below 300rpm may be fine for a gtst, because it wont be on boost, but for a gtr (a standard one that is) it is on boost. My car has forged pistons and I find that it wont rev really well because of co;d start requirements anyway. What I do is let it sit there for a couple of minutes till say the water temp guage reads at about 1/4 then begin to drive it, gently of course until fully warmed up. The oil temp guage in the centre, i think this is for the gearbox, will take about three times as long to warm up as your engine, but still be carefull with it until it reaches about 85 degrees.
Hope this helped.
how much it comes on boost depends on how much accelerator you give it. my gts-t would be at 13psi by less than 3000rpm if i booted it, but i could keep it pretty much off boost and drive along at 4000rpm. the more you plant your foot the more boost you are going to give it. not just the rpm.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
