hey guys,
i just had a brand new set of toyo T1R 255 on rear and 235 fronts put on.
everyone seem to be saying they are grippy for street tyres.
i am slipping every time when i put the pedal down. even on 4th gear. the light on the dash keeps popping up... do i need to drive it for another few hundred kms b4 it will start to get grippy?
or do i need bigger tyres? 265 maybe?
my car does not have huge power. i do understand if the wheel spins on first n second but this goes straight to 4th gear.
shed some light please.
cheers!
https://www.sau.com.au/forums/topic/207483-wheel-spin-even-on-4th-gear/
dynoed the other day 280rwhp. tat why i am curious aswell. its not a huge power, but y the "SLIP" light keep popping up.
was driving on the freeway yesterday n when i drop to 3rd & 4th, pedal down it slips. every single time.
I dunno how you could be spinning in 3rd or 4th with 280rwhp mate. I have cheapy nangkang 245s on the arse of mine and it wouldn't spin even in 2nd. Stab the clutch yeah sure you get a bit but wouldn't 'spin'. That's with 270rwhp in a lighter car.
are you refering to the slip light on your tacho as in an Active LSD?
slip light on the top of the tacho.
the car is a r34 gtt and it comes with the tsc(traction control)
Edited by lcy
How stiff are your springs?! lol
I'd take a guess here and say your traction control may be playing up.. when the light comes on, can you actually feel the rear wheels spinning? or is the SLIP light coming on with no wheelspin? May be a fault. It's also possibly something to do with your ABS as the wheel speed sensors can affect the TCS.
Why don't you turn traction control off and see that your wheels won't spin....in any gear for that matter unless you clutch dump it or power over in a corner, especially with T1R's. Otherwise it's probably as stated already and your clutch could've seen better days.
edit: added info
Edited by KeyMaker
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
