[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
sheeeet....
Was this 1000 rated or 2000??
Isnt there 1 or 2 guys that have installed them?? Anyone else had dramas??
  • Replies 717
Hey Marc??
You have his Phone number.. i'll talk to paul.. but i'm not sure whats going to happen over xmas eh..
thats so shit this better not happen again!! f**k this has been the worst idea i have had ever.
I feel sorry for ya andrew..you had all good intentions and I was planning on buying this anywau when it popped up here on SAU i jumped all over it..hope it all pans out well and it was just 1 dud...but with suss fittings i reckon everyones a bit aprehensive...
rated to 2000..............................................................!
i cang et the number again, but james does fark all! he sits on his a55 doing bugger all and then lies about deliveries being sent... So, i dont particularly want to chase up that chap.
Rang jim Leslie the Director at ACPT. I am getting the money back and a free carbon 2000hp 'correct' shaft. He was rather pissed that some moron sent out the wrong tubing...
Oh well, free shaft for my customer.
Happy days!
Email
Marc,
As we discussed on the telephone, this shaft was not built with the correct tubing. The diameter should have been 9.6 cm (3.8 inches).
We have built hundreds of shafts for Skylines and usually don’t have any problem. I hope your customer is happier with a refund and a new shaft on it’s way. I’ll monitor the build from this end. Please let me know how it works. James should get a shipping date to you, but it will be after the New Year’s Holiday due to the balance shop being closed.
I apologize for the problems you have had with our company.
I hope you are having a great Christmas!!
Jim
Jim Leslie is a genuine guy, he has pulled their heads in over what has happened on here. He said that he only found out about this whole debarcle a week ago and has found the employees responsible, very angry at the ACPT name being associated with malfunctioning product and incompetent production rates.
So, hopee all of you got the correct tubing size. Ours was out by 1 full centimetre....
Well after measuring the circumference and using this calculator http://www.csgnetwork.com/picalc2.html mines about 9.55cm ..
so where does that leave me now....is .45 difference okay or is she going to bust apart..
Think everyone should do a measure and see what we come up with..
just measure circumference and divide by 3.14159 (PI)
Edited by elrodeo666
Unless my math is wrong, that is 0.05 diff, which is probably not important.
Although I don't understand why tubing dia, visually pretty much right (how much was it wrong by?), created a shaft
that looks as though it would not handle the torque of a civic, let alone 2000 hp.
And what about the wrong sizes in the other direction.. is that down to the same malfunctioning individuals?
Edited by r34nur
Shaft + Money=Win!
Good outcome. Maybe this thread should compulsory reading for anyone wanting to start a GB, I don't think I would take one on. My shaft will be in Perth soon, fingers crossed, and I'll get it measured.
Glad its all working out fine, as Marc said Jim from Acpt is great to deal with i wish he was on the case from the start..
as for Paul, He's thrown in the towel.. so if someone wants to be the distributor for Acpt its up for grabs...... this even comes with free INSANE stamps for everyone involved :banana:
Never again for a group buy is what i say... i hope that everyone else's shafts are correct..
hey guys,
I'm going to measure mine.
I took the car to the drags the other night. It withstood 2x passes I ran 11.1 @ 125mph best and up top end it had some pretty serious vibrations... Iv'e never had a prob like this before. Not blaming the shaft yet, will measure it up also, check a few things out, might even trial fit the stock one again to make sure the shaft is the problem....
sigh.
Michael
Fark! it's pretty clear where and why it failed. you can see it's snapped right at the end of the steel insert for the mounting hardware. nasty.
hopefully the correct shaft will be ok, and money back shows at least the director is serious about attempting to mend his companies reputation with you guys. he should praise jeebus that nothing really bad happened when it failed, like the car getting launched, pieces penetrating the cockpit, major accident etc etc. very lucky.
hey guys,
sigh.
Michael
Be interesting to see if you still have these vibrations.
Was it in any particular gear?
well, could have only been in 4th... That's when I really noticed it.
Havent driven the car since, so will be getting under it this weekend and investigating then going for a drive.... :happy:
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
