ok now we all know that the PFC is the way to go for ultimate tuning but PFC's are getting pretty hard to find these days for a R33 GTST so my question is whats the next best thing to use if one cant find a PFC???
do i just stick to a piggy back or is their another replacement ECU that can be compared to the PFC???
ta
Ash
https://www.sau.com.au/forums/topic/209764-pfc-alternative/
Depends what your aims are... for your everyday streeter with a hi-flow turbo, slightly bigger injectors etc. an E-Manage Ultimate would be more than enough. If your going to make big power it would be better to spend the extra money and get something that's suited for tuning big turbo's i.e Autronic.
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3708492
PLEASE DONT GO A EMU DUDE THEY SUCK BALLZ.
no one tunes them. it is VERY hard to tune, i was quoted that they needed 3 days to do the tune!!!!!. it bollocksed up my ecu. made error codes. then removed it and ran just stock ecu and it runs.
so im going a power fc.
good thing im getting my money back on the EMU. whoo lesson learnt. just because its new doesnt mean its good.
BUT. have heard nothing but good news on the e11v2. i believe the ignition jet200 uses one.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3708652
go the powerfc, sorry wins hands down in most cases unless you can afford wolf 3d, autronic, motec
it just seems with the other piggyback style systems you need to find a competent tuner
then you are back to the old remap style issue where only 1 or 2 workshops can do / fix it / tune it
so your stuck with lack of competition, options and alternate/cheaper pricing
if i was to do another car , powerfc no questions
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3709048
powerfc is old and overpriced.
E-manage Ultimate is the best replacement for the pfc.
people seem to think it just another safc but it is far from that and is alot better than the pfc in my books. able to have more than one map sorted in the ecu and change maps on the fly by a flick of a switch, launch control, ignition cut limiter just to name some of its features.
seem one in action and if the tuner knows what he/she is doing they are a great ecu. their are cars in Japan running over 500hp with the ultimate (Trust/Greddy D1 s15 for example)
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3709101
Apexi PFC - stand alone/plug & play
Wolf 3d - stand alone/plug & play
Greddy E-Manage Ultimate/blue - Piggy back
Old & over priced?
I'd say one of the best value for money ECU's on the market - it does everything a stand alone ECU should do without any fancy unnecessary useless features
Its been around for years and will be for many more to come
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3709201
Old & over priced?
when was the last time apexi update the powerfc? And last time a check Apexi are no longer producing alot of its PFC models
best value for money? no thank you $1500 for a basic ecu (r33/r34 prices) - when you can get the ultimate which does exactly the same as what the pfc does for alot less ($1000 or under) oh and it has more function than the pfc too
so what is the greddy is a piggy back? why does that make such a bad ecu?
Edited by [Michael]
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3709220
Never said it was bad, I'd prefer to go a plug and play over something that cuts into your loom
Also for EPA/defect reasons
+ installation for the E-MANAGE - its just easier to go a plug and play and might even work out cheaper
Unless you want to pay for the wiring harness etc - by the time you get all that, you might as well spend a little more and go a stand alone ECU
$1,500 is an overstatement, if you look hard enough you will find one for cheaper than that
I know someone who bought one off this forum for $1,000 brand new with HC - that wasn't to long ago either
I also bought a AP Engineering one for $1300 delivered - people are asking anything up to $1600, it just depends on how hard you look
Basic ECU if you think so but it does everything you need it to do for a tuned street/track car
If you were going all out with a spastic track car - 1000hp style then I'd say AUTRONIC or MOTEC but whats the max he will go with an RB25, 300wkw maybe?
PFC is more than capable of handling that
Updated? What for - it does what its designed to do and always has
https://www.sau.com.au/forums/topic/209764-pfc-alternative/#findComment-3709239
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
