hey guys just checking with the experts, i've just been quoted $2944.54 to have my pads changed on all 4 corners is that right???
from Nissan Werribee:
labour: $200.00
Front Pads: $1500.34
Rear Pads: $1244.20
Total Cost: $2944.54
is it me or is that a tinny bit expensive?
https://www.sau.com.au/forums/topic/210065-oh-sht-no-breaks/
labour: $200.00
Rear Pads: $1244.20
WTF!?
Please tell me your referring to simply brake pads on all 4 wheels and not caliper/rotor upgrade etc.
That price seems more like an upgrade because pads should not be more then $200-$300...
Regards,
Jack
Your getting a car serviced @ Nissan?
lol... dude your crazy. Dont go near Nissan as its not locally delivered
The only thing you go to Nissan for is parts that you cant find second hand/new from a wrecker, and then ONLY if you can get trade pricing :blink:
Should only be a few hundred from any decent workshop which can be found in the sticky thread about it...
http://www.skylinesaustralia.com/forums/Lo...ops-t13305.html
labour: $200.00
Rear Pads: $1244.20
Do you even need to ask?
Call up racebrakes, tell them what the car will be used for and get the pads they recomened. Or check out any of the recomended workshops (sticked in the Vic section) and give them a call for a quote.
thats probably using brembo pads, fluids and proper service schedule checks etc
would also include machining rotors etc so yeah you can probably see why its so much
i rememebr someone talking about bnr34 compliance and if the workshop doesnt use the original brembo pads then you have
to fork out for a complete new set of brembo pads which is like $1500 or something spastic
but yeah any brake place can fit pads and do the normal work
heck even abs.com.au can do it - auto brake service, just a mainstream brake place
less a bit of the huge markup a Nissan dealer would charge, those prices are unfortunately about right.
As paul has pointed out, if a compliance workshop deems the brembo pads are less than 50%, bang, $1500 - $2000 added to your compliance cost due to genuine brembo pads.
so Nissan is at least correct in what they're quoting, albeit at inflated dealer prices.
If it's not compliance related, you can source some after market pads but you might have trouble finding ones that fit the brembo calipers. I think QFM can put whatever of their compounds you want onto your backing plate.
But yes, genuine brembo is very pricey and as others have said, prob don't want to go near a Nissan dealership.
Are your brakes rooted?? or they getting on in life?
by the way, your car is ridiculous HOT!!
i wasn't planning to go there but was just wondering how much it would cost, didn't think that i'll have to take out a personal loan to get my pads done at Nissan.
getting it done at Racepace, that's where i got my stage 1 mods and all my 5000k services. :D Ben recommended Bendix Ultimate but the guy at RaceBrakes says it's shit what do u guys/gals think?
well it's agreed will never take GTR to nissan :P never never never
It really depends on what you want out of your GTR, if it is a daily driver then Bendix Ultimates are a really good street pad, they produce quite a lot of brake dust but I have used them of a few different cars and have found them to be considerably better than the stanard pads.
I dont know how long they would last on a track though, as I have only used them for street use.
Cheers
Dave
that is a straight up fkn rip off man - 3k for brake pads is a joke!
Have you considered giving it a shot your self - its not very hard and there should be a write up somewhere on the forum
if not then that’s fine - just get a reputable work shop to do it so you don’t get ripped off
ultimates from quite a few accounts prob won't cut it on the track, especially with the speeds your car is capable of.
re: brake pads.... how much track time are you considering??
in case you don't know, go to finalinspection.com.au to keep your car clean :)
