OK we are in the process of taking measurements for the oil and water lines. But we cannot figure out how to run the water feed and return with a Greddy plenum installed.
Here is a pic of the inlet side of the block,can someone tell me what this bolt is? There is another one on the exhaust side under the welsh at the back of the block. Both of them are just screwed into the block.
they are the oil and water drain bolts....leave them in.
OK all, went to GCG and got the fittings,gaskets and oil drain for the turbo.
Also took measurements for all of the lines(good old string).
Took them all down to Pirtek to get all the lines and extra fittings needed. The guy there was very helpful and even custom made a few of the fittings to meet some of my clearance requirements. One thing which worries me though is the fact that the water return from the turbo to the block will have to be fed down through the exhaust manifold, Mr Pirtek man assures me the braided line will be up to the job.
Ill be using hi-temp silicone hose for the both the turbo and external head oil drains.
I also bought some bright silver engine enamel for the CAS, as against the new covers the stock finish will not cut it.
i give that line 6 months before the inside crumbles up (even if its teflon lined)
you should hard line them all now :D
heres what i did with anna's engine.
all the lines are insulated and run down the back of the motor. the 90 degree fitting on the turbo was replaced for a 130 degree for a better fit. :D
water lines are as follows, out of the standard position at the rear heater hose, thru the turbo and round the back into the throttle body out of the throttle body into the bottom hose nipple on the block.
I just took a measurement of the fitting i have on the external oil drain on the head. It sticks out 6cm. Will this hit my firewall?
is it a forged 90deg elbow?
if its not it will probably foul...pics please :P
yeah will be close. someone shold just do it with a bango instead oneday. i dont use them. cant see whats wrong with the 2 drains in the block directly below that said drain . lol.
anyway...... 7500kms later and with 6 litres in the stock sump still nothing in the catchcan :P
Just in the process of replacing the braid down through the manifold with hard lines. Do yourself a favor and do it right from the get go. The braid has limited life under those heat conditions despite being double wrapped and hard shelled with heat resistant material.
Im wrapping the manifold in heat wrap so i think it wont be as much of a problem. I am now going to route it another way anyway.
+1
My manifold is HPC'd in black and the lines were shielded and the GCG lines still hardened. My oil drain is routed away from the manifold but yet it didnt help :D (there was also a heatshield around the turbo at that time)
Dave replaced the lines (custom speedflow line) when he built the the engine and all the silver tape in the engine bay is the same heatsheild tape as the v8's run....no problems this time round.... :P
Alot more expensive but a perfect fit .....
+1
My manifold is HPC'd in black and the lines were shielded and the GCG lines still hardened. My oil drain is routed away from the manifold but yet it didnt help :) (there was also a heatshield around the turbo at that time)
Dave replaced the lines (custom speedflow line) when he built the the engine and all the silver tape in the engine bay is the same heatsheild tape as the v8's run....no problems this time round.... :D
See how i go with the wrapped manifold and and covered lines. My lines are not from GCG if that will make any difference.
P.S Love the new pic :P
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
