Looks fantastic Dave! I'm going to have to cut the hole for the VCT on the cam gear cover aswell, yours turned out better than i thought. Did you retain the RB25 backing plate or did you use a RB26 one?
Edited by PM-R33
Still has the 25 backing plate, but you will need to shave the top corners a little for them to fit inside the cover.
Ah ok sweet. Really didn't want to take the timing belt off just to change the backing plate haha.
heat tape on the cam cover blends into the ceramic well, took me a while to spot it.
setup looks neat dude, got any shots of where you connected the braid to the factory lines and life pump/return etc?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
