you mean red top SR20, right?
Its a Red R built forged CA18, it was going to be the drag car but now is used as a daily. Its an S13 Silvia with a few GTR bits bolted on. We got pulled over in it on Saturday night when Paul was running me home but as it appears to be totally stock they left empty handed, lol.
Edited by blitzxtr
I have ordered a ASR RB30 Custom Race sump. Should take about a week to fabricate once it lands in Vic.
8.5L capacity, heavily baffled, windage doors. Boxed around the pickup. Also modified pickup.
Paul also decided to half grout fill the block, he was doing 2 other engines and had some left over lol
Looks like a new turbo setup is on the cards as this bottom end will be laughing at anything the 35R can throw at it.
NOTE: Selling a Brand New set of CP RB25 pistons. $1050+post.
16 valve :D
Must be an oldschool silvia or something.
Ah...didnt look closely enough
The new turbo wont be happening for a while. But when it does it will be a HKS T51R KAI.
Ohhh nice...what about somthing Twin Scroll though? like a 4088 or something?
Paul has a history of making at the tyres what the HKS turbo's are rated at the engine, the head needs the right little tricks though. Put the 25 head on then save some cash for the big head...or when Paul is not looking steal Twoogle's!. lol
Dave, 800whp response monster, should be fun at E.C. lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
