you mean red top SR20, right?
Its a Red R built forged CA18, it was going to be the drag car but now is used as a daily. Its an S13 Silvia with a few GTR bits bolted on. We got pulled over in it on Saturday night when Paul was running me home but as it appears to be totally stock they left empty handed, lol.
Edited by blitzxtr
I have ordered a ASR RB30 Custom Race sump. Should take about a week to fabricate once it lands in Vic.
8.5L capacity, heavily baffled, windage doors. Boxed around the pickup. Also modified pickup.
Paul also decided to half grout fill the block, he was doing 2 other engines and had some left over lol
Looks like a new turbo setup is on the cards as this bottom end will be laughing at anything the 35R can throw at it.
NOTE: Selling a Brand New set of CP RB25 pistons. $1050+post.
16 valve :D
Must be an oldschool silvia or something.
Ah...didnt look closely enough
The new turbo wont be happening for a while. But when it does it will be a HKS T51R KAI.
Ohhh nice...what about somthing Twin Scroll though? like a 4088 or something?
Paul has a history of making at the tyres what the HKS turbo's are rated at the engine, the head needs the right little tricks though. Put the 25 head on then save some cash for the big head...or when Paul is not looking steal Twoogle's!. lol
Dave, 800whp response monster, should be fun at E.C. lol
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
