  • 5 months later...
Thread revival.
After powercruise I had decided to leave the drag radials on, ordering a another pair soon so I can put my 18s back on the rear. Its the only tyre that has decent traction.
Took the car to the drags in June and only managed a feel out run before I destroyed the diff and snapped a half shaft :(
The spline from one of the shafts spun inside the axle gear which pushed it apart, then the other shaft snapped clean. Even though one gear broke I had to order two from Tomei which was a wallet killer! Could have almost bought a new diff.
So I only did a 12.3 at 137mph.
Done a few cruises and all up put about 1500kms on the motor. Took it out last night for a run up the mountains to fill up at the new United in Blaxland that sell E85.
Much better drive for me than going to Rozelle for fuel.
So now Im just doing some little tidy up stuff and would like to get the car resprayed at some stage.
Here are some vids from last night:
Awesome car! I love the first video of you feathering the throttle on flyby, awesome power and sound!
Do you also run on 95ULP at times or just E85 the whole time? Do you need to make any changes to the management system or does it self adjust to accomodate between the different fuels??
I've got a United servo near me that sells E85 (conveniently on the way to Calder Park too) so would love to run the odd tank here and there but not all the time. I've got a Power FC though.
Cheers.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
